Bravo Brava airbag computers no communication
madman47
Post by madman47 » 21 Jan 2012, 07:05
Hello!
Can you please advise me.
I am trying to communicate with 1996 Fiat Bravo/ Brava Airbag computers.
I have tried several, and none have any communication....
46413633
464793640
Are these the BREED ones given in the options??
It has the 3pin plug, im using a KKL with a registered version.
Thank you kindly
ducatis4
Re: Bravo Brava airbag computers no communication
Post by ducatis4 » 05 Mar 2012, 17:19
idem,
I have the same problem with airbag fiat marea jtd 1999 105 (airbag allied ...)
many have this problem, how can we find solutions?
cables are installed correctly (I think) work well with other vehicles, no connection failed with my 97 allied airbags tidal good good jtd 105 99 3 pin.
KKL + 3 pin adapted
help....
ducatis4
Post by ducatis4 » 10 Mar 2012, 14:02
I still have connection problems with 3.4.2, I checked the sequence of the 3-pin adapter cable. is ok.
no communication with:
- Support for Allied Signal old airbags (Marea, 156)
- Support for old BREED airbags (Bravo / Brava) :shock: :shock: :shock: :shock: :!: :?:
Post by yani » 10 Mar 2012, 14:28
Can you send me reports after failed connection?
I've tried this on a '97 Marea (which has 3-pin connector, where only k-line and GND are connected) and on Alfa 156 (which has 16-pin OBD connector, the airbag needs k-line connection on pin 3).
I tested it with 2 different VAGCOM interfaces and it works fine on these cars.
Zwierzak
Post by Zwierzak » 10 Mar 2012, 15:59
I also can't connect to airbag my99 in Panda using KKL
ducatis4
Post by ducatis4 » 22 Apr 2012, 01:21
Errore DI COMUNICAZIONE airbag fiat mare jtd 105 '99
NON RIESCO A COLLEGARE L'AIRBAG
RICERCA ECU: Risultati:
CLIMATIZZATORE
UNKNOWN / UNSUPPORTED
ISO CODE: 49 85 01 94 38
AIUTO.
Modano
Post by Modano » 22 Apr 2012, 09:16
Hi ducatis, In my Marea
there are 3 or 4 3-pin connectors, 1 for ECU, 1 for ABS, 1 for Airbag and 1 for AirConditionning.
Maybe you're not connecting to the right one, as it is finding the AirCo plug ?
ducatis4
Post by ducatis4 » 22 Apr 2012, 22:14
the plug "air conditioning" is under the storage compartment, where can I find the plug airbags?
ducatis4
Post by ducatis4 » 22 Apr 2012, 23:04
okey. I found the plug. is inside the trunk, you have to remove the panel, it is ok multiecuscan, tnk
