service reset on Panda 4x4
chris h
Post by chris h » 11 Jan 2012, 14:46
I am having a problem resetting the service light on a panda 4x4 1.2 55 reg. The ECU scan will not communicate with service option, also the engine management light is flashing constantly but there are no fault codes stored. The chassis No is ZFA16900000489186 can i go in under a different model or will this not work on this car.
Chris
Zwierzak
Re: service reset on Panda 4x4
Post by Zwierzak » 11 Jan 2012, 19:35
When you have hot engine try accelerate 3 times do 6500 RPM
Juggers2k
Post by Juggers2k » 12 Jan 2012, 11:27
Zwierzak wrote:When you have hot engine try accelerate 3 times do 6500 RPM
At the risk of asking a silly question, what does that achieve?
Zwierzak
Post by Zwierzak » 12 Jan 2012, 12:43
chris h wrote:the engine management light is flashing constantly but there are no fault codes stored
Chris
I suppose that this is problem with phonic wheel adaptation.
