Fiat Bravo 99 without OBD
kecka
Re: Fiat Bravo 99 without OBD
Post by kecka » 26 Dec 2009, 18:28
ne neni zbytecna :D :D :D po K lince to zrovna komunikuje !!!! L linka je na stare auta ;) ;) ;) ktere potrebuji obe linky........
Ja tu redukci taky nekdy pouzivam.........
bady555
Post by bady555 » 27 Dec 2009, 08:26
praveze podla schemy co je tam, je stred kostra, to je OK, ale pri tej ciarke, kadial ide signal v 3 pin-e je linka L podla obr, a linka L ide na 15 pin v OBD...a linka K ide na 7 pin OBD...lebo bravo 99,marea a pod maju zive len 2 piny a podla shcemy je to kostra a prave linka L
kecka
Post by kecka » 27 Dec 2009, 15:40
To neres proste nasad konektor a diagnostikuj...... ;) ;) ;) ;) ;) konektor je zapojeny dobre :) :) :)
alfabug
Post by alfabug » 28 Dec 2009, 02:11
ehernanz wrote:I have this cables:
409
Fiat 3 pin
But not works... why?
What should I do?
Hi ehernanz,
Do you mind sharing where do you purchase 16 pins OBDII cable from?
thanks,
alfabug
ehernanz
Post by ehernanz » 28 Dec 2009, 12:21
I'm spanish... and i buy this cable in Mediakit2010.com url: http://www.mediakit2010.com/modules.php ... ts_id=1431
alfabug
Post by alfabug » 28 Dec 2009, 13:36
bravo has a few 3 pins connector. may sure you get the ECU one to diagnose fault code for engine. Is the cable working for any car yet?
ehernanz
Post by ehernanz » 28 Dec 2009, 17:53
I ran without any problems on a Fiat Bravo 99 without OBD connector (with 3 pin).
Tenebrae
Post by Tenebrae » 28 Dec 2009, 20:57
bady555 wrote:praveze podla schemy co je tam, je stred kostra, to je OK, ale pri tej ciarke, kadial ide signal v 3 pin-e je linka L podla obr, a linka L ide na 15 pin v OBD...a linka K ide na 7 pin OBD...lebo bravo 99,marea a pod maju zive len 2 piny a podla shcemy je to kostra a prave linka L
Ahoj, komunikace jde po K-line a tak to je i na schéma, akorát se na to díváš obráceně, na tom schématu na první stránce je zobrazen konektor na autě, nikoliv na kabelu, jinak čárky tam jsou dvě, jedna je uprostřed mezi K-line a kostrou a ta druhá čárka (zobrazená na schematu) je mezi volným pinem a kostrou, začíná hnedka od začátku konektoru. Jinak ty konektory mají očíslované piny, takže se stačí podívat, čísla jsou vždy proti sobě, na autě je pin č. 1 nezapojen 2. je kostra a 3 je k-line. ;)
alfabug
Post by alfabug » 29 Dec 2009, 13:18
ehernanz, thanks for the info and great to hear the cable works.
bady555
Post by bady555 » 29 Dec 2009, 16:33
tak vdaka, potom tomu uz chapem, kedze je to koncovka v aute a nie na kabli tak potom je to naozaj otocene...este raz vdaka za vysvetlenie
