Page 12 of 20
Re: VAG KKL cable connections
Posted: 08 Dec 2013, 17:40
lolo85v wrote:Good evening can you tell me on what(whom) position the kkl has to be for the reset drain away on 159? Thank you
I have to try quite position but its pass not
Posted: 10 Dec 2013, 21:59
by lolo85v
What position of swicht kkl for draining alfa 159? Thank you
Posted: 11 Dec 2013, 07:21
Hello lolo85v
The KKL interface you can only read the engine ECU with an Alfa 159
nothing else (ok well the ABS)
Therefore, you need not switch the KKL interface but only a bridge from
Pin1 to Pin 7
For all other controllers you need an ELM interface
Posted: 11 Dec 2013, 19:48
by lolo85v
Thus for the reset draining I has to make a bridge(deck) between 1 and 7?
http://i57.servimg.com/u/f57/13/84/33/82/20131212.jpg
Posted: 11 Dec 2013, 21:57
Hello Lolo85v
For draining?? what you mean?
Ok now i understand, you have a switched KKL Interface
from this interface you must not make a bridge from 1 to 7
Everything OK
It is difficult for me to translate your post
Posted: 12 Dec 2013, 12:52
by lolo85v
I use a translator
Posted: 12 Dec 2013, 18:04
lolo85v wrote:I use a translator
Hello lolo85v
Now I understand why I can not read your posts :lol:
Posted: 17 Dec 2013, 05:17
by Monax
Hello guys. I need your help. Can i connect VAG KKL with mine Fiat Grande Punto. I was read that, it will not work. But i ordered it. What can you say. Thank you for answers)
Posted: 17 Dec 2013, 07:29
Hello Monax
You need an ELM Interface and an Adapter A3 ( yellow) for the Grande Punto
With your KKL Interface canĀ“t nothing read any control
All controls in Grande Punto read in CAN Bus and KKL can not read CAN Bus
Posted: 17 Dec 2013, 07:38
by Monax
Eddy Thanks for answer. My order is failed. Minus 16$ for me(( Now i know that i need only ELM
