Problem connecting to CAN
dfi
Post by dfi » 12 Aug 2011, 07:52
I have a OBDLink interface, I can connect to engine via k-line but not via CAN. The CAN works though in VAG engines. I have sent the error log, is from a fiat punto. Thank you.
Re: Problem connecting to CAN
Post by Alfaeddy » 12 Aug 2011, 08:14
Which OBD interface do you have?
Without a more accurate description you will be able to help a little.
Do not hesitate to FES / Settings / Interface a test, and fix this one
dfi
Post by dfi » 12 Aug 2011, 08:20
I already said the interface is OBDLink from ScanTool.net. I nhave also tried on fiat ducato and doblo and the same issue, it won't connect on CAN.
Also, forgot to say, FES is registered.
Post by yani » 12 Aug 2011, 10:15
I saw your log files.
The interface cannot connect to the CAN network and gives error. There are other people who reported problems with this OBDLink interface. So, probably you need to get an ELM327 interface and try with it.
dfi
Post by dfi » 12 Aug 2011, 10:52
So isn't there a workaround to my problem? maybe change some of the programmable parameters, or changing the speed of the interface?
Post by Alfaeddy » 12 Aug 2011, 12:31
So my question for a screen test
Then you could possibly see where the problem is with the interface.
