Hi guys, i have a Grande Punto 1.4 Tjet 120cv and i have bought an ELM 327 1.4 with Fiat ECUscan 3.0.2 registered.
The connections is ok, when i enter in the ABS/ESP module, the car signal an error (ABS,Hill Holder not available).There are no fault code in the module.
When i exit from the module the error disappear.Is it normal ?
Thanks for the answer !
ABS/ESP module problem ?
Re: ABS/ESP module problem ?
Yes, this is normal. When the ABS modules goes into diagnostics mode the dashboard shows error message.
