Does Multiecuscan work on Iveco
scaramush2010
Post by scaramush2010 » 02 Jun 2011, 15:56
Hi there Just wanted to know if Multiecuscan works with Iveco Daily and Euro Cargo
EnIgMa
Re: Does Multiecuscan work on Iveco
Post by EnIgMa » 03 Jun 2011, 12:28
I don't know but try to check out the type of ecu installed, search if the same ecu is supported in FES then maybe...maybe...it could work. :)
Post by alfa156sarajevo » 03 Jun 2011, 13:21
EnIgMa wrote:I don't know but try to check out the type of ecu installed, search if the same ecu is supported in FES then maybe...maybe...it could work. :)
I agree with EnIgMa... ;)
mattydr67
Post by mattydr67 » 07 Jun 2011, 05:45
Uveco Daily and EuroCargos ECU's:
Powertrain:
-Bosch EDC16C39 Iveco
-Bosch EDC16C9 Iveco
-Bosch EDC7 Iveco
-Bosch MS6.2 Iveco
-Bosch MS6.3 Iveco
Chassis:
-Bosch ESP 8.0 Iveco
scaramush2010
Post by scaramush2010 » 11 Jun 2011, 10:31
Thank you guys for the info I will try and let you know.
