VCDS HEX-COM+CAN Interface Ross Tech
rafal
Post by rafal » 14 May 2011, 14:08
Hello. I have got interface from ross tech as subject and my question is: can I use this lead with multiecuscan software?
ivica21
Re: VCDS HEX-COM+CAN Interface Ross Tech
Post by ivica21 » 15 May 2011, 07:20
No.You must have kkl, elm327 or OBDkey
ELM327 v 1.4
rafal
Post by rafal » 15 May 2011, 12:05
I have got ELM 327 and I know about these but my vag com has got as well KKL.
http://www.ross-tech.com/vag-com/hex-usb+can.html
sorry for wrong subject because I have got USB one.
So if I have got ELM 327 I do not need vag com KKL?
Because I bought as well adaptors from Gendan (red,yellow,green)
Juggers2k
Post by Juggers2k » 16 May 2011, 08:46
The HEX-USB+CAN can't be used as a KKL - it is recognised as a USB device by Windows as Ross-Tech use their own drivers. The KKL interfaces appear to Windows as a USB serial convertor, allowing software like FES to address them as a COM port.
Whether you need a KKL aswell as an ELM will depend on the vehicles you're covering - some modules require the ELM, others require the KKL - see the supported vehicles list.
Post by alfa156sarajevo » 16 May 2011, 17:14
Juggers2k wrote:The HEX-USB+CAN can't be used as a KKL - it is recognised as a USB device by Windows as Ross-Tech use their own drivers. The KKL interfaces appear to Windows as a USB serial convertor, allowing software like FES to address them as a COM port.
I agree with Juggers2k! ;)
rafal
Post by rafal » 16 May 2011, 18:58
Thank you for all for answer. I bought already KKL lead as well.
Regards!
