Grande Punto 1.3 MJT spia olio motore
fabinger
Post by fabinger » 13 May 2011, 09:11
Buon giorno a tutti, ieri ho comprato multiecuscan 2.8.2 e tramite ELM 327 sono riuscito ad entrare in centralina motore per spegnere la spia dell'olio in quanto ho cambioto l'olio.
Quando ho riacceso il quadro peò la spia continuava a lampeggiare.
Come posso fare?
Grazie a tutti.
Good morning everyone, yesterday I bought multiecuscan 2.8.2 by ELM and 327 are able to enter the engine control unit to turn off the lamp oil because I changed the oil.
When I powered on the part ment the light was still flashing.
How can I do?
Thank you all.
Re: Grande Punto 1.3 MJT spia olio motore
Post by yani » 13 May 2011, 11:44
Did the "Oil Change" procedure completed with SUCCESS or FAILED?
Did you also reset the service interval?
fabinger
Post by fabinger » 13 May 2011, 12:01
The oil reset procedure is successful.
I also reset the service interval.
When I turn off and turn on the oil light starts to flash.
dallas140cv
Post by dallas140cv » 14 May 2011, 07:25
Your vehicle has the DPF, so you have to go in parameters of engine ecu and make the "oil change dpf reset" procedure.
fabinger
Post by fabinger » 14 May 2011, 13:11
Thanks dallas I do that procedure, the system tells me that the procedure was completed, but when I turn off and turn on the context, the oil light starts to blink again.
