unknow body computer
zcizek
Post by zcizek » 10 May 2011, 12:36
I can not do 'Proxy alignment procedure', because my car (Stilo 1.4 16V, year 2007) can not communicate with sw 'FES: 2.8.2' and interface 'ELM 327 v1.4'.
After scan (F11) it show report with result: Body computer - UNKNOWN/UNSUPPORTED (ISO Code: 40 83 A7 85 C4).
How to connect and to do 'Proxy alignment procedure'?
Thanks.
Re: unknow body computer
Post by yani » 10 May 2011, 14:25
What happens when you try to run the PROXI procedure?
zcizek
Post by zcizek » 10 May 2011, 15:14
CAN Setup writes: check your cable and serial port setings
Marelli MF Body Computer writes: Invalid ISO Code
CAN CONFIGURATION DATA:
01 00 01 6F 00 00 01 6F 00 00 00 41 00 00 00 01 00 00 00 00
30 34 31 39 32 30 32 39 38 34 38 4F 55 54 50 55 54 2D 4A 49 54 20 06 03 15 6F 01 00 01 09 01 00 01 83 40 00 00 00 14 16 00 00 01 44 06 00 00 00 28 00 00 00 11 50 B3
Index je mimo hranice pole.
