Diagnostic Hardware Bundle for Multiecuscan (Fiat/Alfa)
Franz_@
Post by Franz_@ » 30 Mar 2011, 11:41
Hello everyone
I write in this forum to say that I have bought multiecuscan
with this product have also obtained the kit interfaces.
It is sufficient for all systems?
'cause I can not connect the instrument panel
a Fiat Doblo '1.9 mjet 8v 2007 cause I asked a OBDKey - 1:40 OBDKey without adapter that I did not have.
could you tell me what is it?
Juggers2k
Re: Diagnostic Hardware Bundle for Multiecuscan (Fiat/Alfa)
Post by Juggers2k » 11 Apr 2011, 13:51
The last time I checked the supported vehicles list (http://www.multiecuscan.net/SupportedVehiclesList.aspx), every vehicle application that used an OBDKey interface is also covered by either an ELM or KKL interface, so you should not need the OBDKey aswell.
The only adaptor Gendan does not supply that you may need is the 3-pin adaptor for some of the early models.
