GENDAN creates FIAT ECUSCAN Hardware/Cable Set
Post by s130 » 22 Sep 2010, 10:58
Right guys and gals
I know Yani does not like recommending or posting specific hardware recommendations so I will.
Gendan a UK company have produced two rather neat kits for Multiecuscan users.
1) A complete pacakage of VAG KKL interface, Elm V1.4 interface and two additional patch cables. see here: http://www.gendan.co.uk/product_FESHW.html
2) Just the two patch cables. see here: http://www.gendan.co.uk/product_FESCBL.html
Now I've already modified my KKL and Elm cables so am a little upset as the two patch cables would have saved me a load of time, but that is life. I'm going to buy the two cables anyway as it is the safer solution if you are ever going to use your KKL / Elm units on vehicles other than Fiats.
lenin
Re: GENDAN creates FIAT ECUSCAN Hardware/Cable Set
Post by lenin » 23 Oct 2010, 20:29
Thanks for the posting . I was about to buy a modified vagcom cable (four way dil switch) thats available on ebay at the moment (£29.99 delivered) . I currently use multiecuscan and Alfadiag through a bog standard Vagcom usb cable. Forgive my ignorance , is the Elm interface used for CAN ?
Juggers2k
Post by Juggers2k » 17 Jan 2011, 18:13
Gendan have updated their packages today to include 3 adaptor cables rather than the previous 2.
The cables they have now match up with Yani's Adapter 1 / 2 / 3 on the supported vehicles list :)
Post by yani » 17 Jan 2011, 20:19
I'm thinking about adding a new feature in the next release to ask the users to insert the correct type of adapter cable before connecting. Something like "PLEASE CONNECT ADAPTER CABLE 1 (GREEN)" ...
alpha
Post by alpha » 17 Jan 2011, 20:43
Hmm expensive stuff !!!
Juggers2k
Post by Juggers2k » 24 Jan 2011, 11:32
For anyone that bought the original Gendan pack, they're also now listing the new yellow adaptor (adapter 3) on their website individually:
http://www.gendan.co.uk/product_FESYELLOW.html
As well as the CAN mappings, this lead has a single pin 7 to pin 12 connection for the Fiat Croma coverage that would be missing from their previous 'adapter 1' cables.
dave fiatforum.com
Post by dave fiatforum.com » 01 Feb 2011, 22:04
what am i doing wrong? i have the gendan set ( eventually found it delivered to under car in garden, but thats another story), i plug in the elm set port same as in device manager set speed same as in device manager, did test and it was ok, then whent to do proxy alinement and it kept saying error check lead and port setting, dont think it needs adapter i tred them anyway got same message.
whent back to setting doubled checked them they seem right, tried to run the test again and it says timed out.
think i am using right lead
[ATTACH]86383[/ATTACH]
only 1 light is on on the blue box and that is power light, and ignition is on
edit car is punto mk2b 2005 1.2 8v
but if i click scan, it says scanning for modules, then done!
is the lead they sent me a dud?
Post by yani » 01 Feb 2011, 22:24
You have to set the port speed (under Test button in Multiecuscan settings) to 38400.
dave fiatforum.com
Post by dave fiatforum.com » 01 Feb 2011, 22:30
ah ok i'll give that a go tomorrow, thanks
dave fiatforum.com
Post by dave fiatforum.com » 02 Feb 2011, 11:53
I have set port speed under the test button to 38400
I have set latency to 1 as advised by some one on fiat forum
test elm connection now works
But i am still getting error check cable and port settings when trying to do proxi alignment :(
the error message is slightly different to yesterday
and all the lights on blue box flashed like a disco
