Works KKL USB INTERFACE with multiecuscan without soldering ?
darioyu
Post by darioyu » 13 Sep 2010, 08:45
HELLO !
I have one question about that.
I will like to use KKL VAG usb interface with multiecuscan.
Works KKL USB INTERFACE with multiecuscan without soldering wire to 1,7,9 pin ?
Do i have to solder a short wire to 1,7,9, pin ?
Is it working (abs, airbag) without soldering a short wire ?
Please answer me.
THANK you !
Re: Works KKL USB INTERFACE with multiecuscan without solderi
Post by s130 » 13 Sep 2010, 17:17
The KKL interface will work without making the wiring modifications BUT WILL ONLY GIVE YOU ENGINE ECU information.
To connect to ABS, Airbags etc. then pin 7 must be connected to the relevant pin.
darioyu
Post by darioyu » 13 Sep 2010, 18:22
thank you for answer !
Can i connect all pins 1,3,7,9 together ?
CAn i damage the car or cable if i do that ?
Thank you !
Post by s130 » 14 Sep 2010, 10:42
See this: viewtopic.php?f=6&t=1499
It is not recommended to connect all the pins together. Much better to use DIP switches or an EOBD patch box.
