Page 33 of 255
Posted: 01 Sep 2012, 23:16
First of all, what Windows system you have on your computer?
32 bit or 64 bit?
And besides, both of the same driver 02:08:24
Try this driver
Posted: 02 Sep 2012, 14:46
by Luckjs93
You mean this?
www.ftdichip.com / Drivers / CDM / CDM% 202.08.24% 20WHQL% 20Certified.zip
But once saved and opened, there is no inside. Exe file that will install
HELPPPPPP
Posted: 02 Sep 2012, 15:14
by stilo1.6
Hi I did everything you have said. Removed two resistance R04 and 2 capacitors soldered and still do not know what a proxy alignment procedure could be the problem? Help me please
Posted: 02 Sep 2012, 17:47
Hello Stilo
Again from the beginning!
I have said to you but that you have to remove the resistor R04!
Only the R04 no other
And I have not written anything of the additional resistors and capacitors!
That are not needed!
This FTDI driver is required if your interface is not recognized!
If your interface detected???
Please look in the Control Panel!
You should not listen to 2 members, it only confuses
Either one or the other!
Posted: 03 Sep 2012, 07:58
by stilo1.6
Alfaeddy wrote:Hello Stilo
szia mi ez a FTDI meghajtó. sajnos ezt nem értem. Azt még meg próbálnám. köszönöm
Posted: 03 Sep 2012, 08:49
by stilo1.6
stilo1.6 wrote:Alfaeddy wrote:Hello Stilo
hey what's with the FTDI driver. Unfortunately, I do not understand. I have yet to try. thank you
Posted: 03 Sep 2012, 09:28
Hello Stilo
Have you installed the FTDI drivers?
- FTDI Treiber.jpg (182.81 KiB) Viewed 6216 times
If your interface detected without error?
- Systemsteuerung.jpg (41.46 KiB) Viewed 6216 times
Have you asked the Latency Time in 1?
- Latency Time.jpg (143.01 KiB) Viewed 6216 times
Otherwise must be some other error
Posted: 03 Sep 2012, 12:10
by stilo1.6
- Képkivágás.PNG (95.17 KiB) Viewed 6216 times
The attachment FTDI Treiber.jpg is no longer available
The attachment Systemsteuerung.jpg is no longer available
The attachment Latency Time.jpg is no longer available
Hi thank you very much for your help and the pictures but I still can not connect to CANBUS. Only motor. Error codes can be deleted. capacitors and resistors R04 and removed. FDTI installed and configured.
Posted: 03 Sep 2012, 12:27
by bricca
Luckjs93 wrote:You mean this?
HELPPPPPP
Hi, how to install this drivers? There is not an exe. Thank you very much.
Posted: 03 Sep 2012, 13:22
Hello Stilo
Of course, your problem is the CAN bus that everything you've removed and soldered it only relates to the CAN protocol.
Your engine control is read with ISO14230
Presumably you've destroyed your interface with your renovation
Once more:
Only the resistance R04 is removed!
