Page 243 of 255
Posted: 16 Oct 2019, 09:55
by Anonymous375298
gsm wrote:
16 Oct 2019, 06:15
So same problem as I have but I can reset oil change light because it is in the motor module of my Ducato with DPF
I don't understand. So you can turn off the light but what you want is change the number of KMs until the next oil change?
Posted: 16 Oct 2019, 16:38
by gsm
I want to switch off the service interval light and that must be done under Service and I can not connect to the service so I can not do service interval reset
Posted: 17 Oct 2019, 14:06
by Blizzard
Hello Guys, i have read alsmost half them with faulty ELM 327 and conection, but stil can't find an answer.
I have the next ELM 327 1.5a, MultiEcuScan 4.4 (free) and Windows 10 64 bit pro
The car of my wife is Mito 1.4T 155hp.
Have a one problem during cold start in the morning in the last some months, and i want to check some sensors.
So that's the ELM module which i bought:
https://ibb.co/wQNC0vt
I have removed the resistor "121" R2 - i think is correct
https://ibb.co/Wc60BM2
https://ibb.co/mGSQRZG
But still not working properly
https://ibb.co/T2NWWzF
When push Scan button to check for inteface and ELM, every moduls say OK, the bottom report lane looks like " This interface is compatible with ELM327 version... and will connect to any CAN module. But the result is on the last picture. I have no idea where is the problem. If someone can help me will be highly appreciated, In my country no one can't.
Thanks in advance!
Regards
Posted: 17 Oct 2019, 17:55
by gsm
Blizzard wrote:
17 Oct 2019, 14:06
I am not familiair with that kind of interface so I can not help you with that one
If I look on page one there they talk about R14 which should be on the backside
Did you choose the right module ? If not then you get the same message
Posted: 18 Oct 2019, 13:54
by Blizzard
gsm wrote:
17 Oct 2019, 17:55
Blizzard wrote:
17 Oct 2019, 14:06
on the backside doesn't have resistors or capacitors is flat plate
Yes ofc there is easy :)
I'll check again with some other drivers, also i have changed the Latency into the registry so we'll see. If have any updates I'll let you know
Posted: 19 Oct 2019, 01:58
by Anonymous375298
Blizzard wrote:
17 Oct 2019, 14:06
Thanks in advance!
Regards
You could ask via email to the distributor of your country about what cable do you need.
Here you have a list of distributors: http://www.multiecuscan.net/Distributors.aspx
Posted: 19 Oct 2019, 08:05
by gsm
Anonymous375298 wrote:
19 Oct 2019, 01:58
Look here, all interfaces are tested with MES and should work fine
https://www.multiecuscan.net/HowToUse.aspx
I bought the Stardiag and I receive it yesterday but I have no time to test it in my Ducato X250 from 2011
And reed https://www.multiecuscan.net/SupportedVehiclesList.aspx
Look at your car model and type and read what you need
Posted: 28 Oct 2019, 15:27
by Blizzard
gsm wrote:
19 Oct 2019, 08:05
19 Oct 2019, 01:58
Hello Guys, thank you for your support but the problem doesn't have touchable points with vehicles list or any other because just i need to connect with the engine, so for there no need any special color cables.
I did another think, have download version 2.1.2 Alfa OBD (it's a one old version of Multiecuscan) but now can connect with the engine, can read data and faults. So i think the issue isn't the ELM module.
Of course i didn't give up to connect with multiecuscan 4.4 and still trying to find where is the problem. If you have any ideas i'm open for them :).
Regards!
Posted: 28 Oct 2019, 19:18
by peppect84
what resistance should I remove from here? I can't understand it
Posted: 28 Oct 2019, 23:53
by peppect84
I tested the resistances one by one, none is 100ohm...
