Page 240 of 254
Posted: 10 May 2019, 20:39
by Rodrigo (rgmm)
Hello people!
Please anyone can help-me to modify my interface to works with multiecuscan 4.2?
https://ae01.alicdn.com/kf/HTB12nnibjQnBKNjSZSgq6xHGXXa3.jpg
The inteface is that model:
https://pt.aliexpress.com/item/2014-Highly-Recommend-Vgate-ELM327-USB-OBD-Scan-USB-Diagnostic-Scanner-Work-With-OBD2-Vehicle-Vgate/453920473.html?spm=a2g0s.9042311.0.0.29c7b90akFQZmN
Thank you very much!
Rodrigo
Posted: 15 May 2019, 04:29
by Lossani
Hello everyone!
I have this sample in attachment. Can anyone help me which resistor I should remove? It worked properly but suddenly it stopped connecting to ECU. Thank you in advance!
https://i.imgur.com/VYHdjGjr.jpg
Posted: 26 May 2019, 20:13
by defender21
Hello, my obd2 elm327 v1.5. bluetoch through program AlfaOBD. Reads only the engine and box. I understand you need to remove the transistor. Thank.
https://ibb.co/8MNxmhq
Posted: 07 Jul 2019, 17:31
by bboy46
Good afternoon everyone,
my name is bboy46 and i write from Italy.
i bought the following ELM327 interface, sold as V1.5 but MES told me that it's a v1.4. i tried to connect with this interface to my car (Punto Evo 1.3 75cv DPF Euro5, 2011) but it doesn't work. i need to reset the service message on my car and to able the cruise control with MES. i already read every of the 214 page of this forum, but i didn't found nothing similar to mine.
Could please any of you help me? could you also suggest me which version of MES can i use?
thank you in advance for your support, i'm waiting for you.
https://imgur.com/ozAogFg
https://imgur.com/CrYI9I0
https://imgur.com/QOm6snW
https://imgur.com/XOicGr3
https://imgur.com/i1SIWAs
https://imgur.com/je1El0g
https://imgur.com/mK6CT8b
Posted: 08 Jul 2019, 18:43
by bboy46
good afternoon everyone and sorry, but i haven't understand how to upload pictures here,
could some of you explain me how can i upload picture here in order to explain better my problem?
thank you again in advance for your support
Posted: 09 Jul 2019, 16:42
You say that MES did not work? Have you purchased a license as for your vehicle the Service Reset and all the other functions require a valid license.
Without a license you can will only be able to read the vehicle CAN bus/device information. You should try to do this to check that you can connect to the car.
Posted: 09 Jul 2019, 16:56
by bboy46
i tried with a free version of MES, and when i go to connect to my car only to test the funcionality of the interface, MES tells me that it's impossible to establish a connection. i tried with a free version of MES to check the interface, so if it works i would buy a MES license.
could you suggest me which is the bettere version of MES for my car (punto evo 1.3 75cv DPF)?
@s130
what do you think about this interface? do you think that it works with MES without modify it? or do you think that i have to remove the 120ohm resistor? and if i have to remove it, could you suggest where phisically is it on the logic board?
Posted: 09 Jul 2019, 18:59
The latest version of MES is always the one you should use. Using an earlier version is only recommended when there is a known regression problem that will need to be fixed in a later/next release.
I have no experience of diagnosing / resolving ELM interface issues as I have always recommended people only buy products from the recommend supplier lists on the MES site.
Others have worked on and resolved issues with some units so I hope that they will respond here.
Posted: 11 Jul 2019, 08:49
by Solarisis
Dear all,
Could someone point me in the right direction?
I have bought an ELM327 clone that should've already been altered in order to function correctly in MES. However, in MES I can start the Proxi Alignment, but it will only write to the NBC:
Writing to module: Dashboard Node (NQS) Unknown error
Writing to module: Climate Control Node (NCL) FAILED! - Unknown error
R04 and R05 are 101 resistors
Thanks!!
Images:
Posted: 15 Jul 2019, 16:20
by bboy46
good afternoon everyone,
today i finally bought a registered version of Multiecuscan. the result is the same. the program doesn't recognize the interface.
please, could any of you help me? i spend 50€ to buy the license for MES. but sitll i can't use it. i already posted the interface i have now, and, in addition to this i also found a Vgate OBD scan bluetooth interface.
could please any of you suggest my how can i solve this situation? which interface between that i have is easier to modify?
thank you very very much in advance for your support,
i hope that someone of you good people will help me
https://ibb.co/PQZGxVM
