Page 155 of 255
Posted: 27 Nov 2014, 19:20
by stroj
it works!!!
danke!
Posted: 30 Nov 2014, 21:42
by Tuner182
I would to ask you for help. I bought ELM 327 mini Bluetooth and read all this forum but there isn´t this same interface. I tried to find resistor R04 or with signature 121 but without success
Could somebody help me to find what I must remove in this interface?
Thank you.
- Elm 327
- 20141130_220454.jpg (269.88 KiB) Viewed 6143 times
- 20141130_220604.jpg (384.6 KiB) Viewed 6143 times
- ELm 327.
- 20141130_220528.jpg (355 KiB) Viewed 6143 times
Posted: 01 Dec 2014, 11:11
Hello Tuner182
On your images you can hardly see anything
No caption read
Why does your Flash Mode, thus is nothing more Readable
Make again a better picture of the resistor R 34 with the chip next
I need to read the imprint
Posted: 01 Dec 2014, 19:30
by Tuner182
Hello Eddy
I made new pictures and hope it will be better visible now.
- 1
- Bez názvu.jpg (888.36 KiB) Viewed 6131 times
- 2
- Bez názvu1.jpg (929.26 KiB) Viewed 6131 times
- Bez názvu2.jpg (1.1 MiB) Viewed 6131 times
Greeting Tuner182
Posted: 01 Dec 2014, 22:33
Hello Tuner182
Remove the Resistor in the blue Frame ( R 34)
than you can read the CAN Bus Protokoll with your ELM
- Bez názvu markiert.jpg (417.53 KiB) Viewed 6130 times
Posted: 03 Dec 2014, 08:57
by Tuner182
Hello Eddy
Thank you for your quick reaction. I removed the resistor R34 and tried to connect to CAN BUS protocol but still nothing. I didn´t have enough time, so i tried it only once. Today or tommorrow I will have much free time, so i will try it again and i will say you if it works or not.
Thank you
Greeting Tuner182
Posted: 03 Dec 2014, 13:41
Hello Tuner182
Was your problem CAN bus ??
What car / controller you want to read?
check out:
- BT connection
- Drivers? not the driver using the Windows finds.
Posted: 04 Dec 2014, 10:05
by Tuner182
Hello Eddy
Maybe I found the problem. I have also wired version of ELM327. I modified it sometimes in the past by the instruction on this page. Propably it was your work thank you. That adapter works and I can connect to all control units in my car. I have Alfa Romeo 159 2.0 jtdm (year 2009). But with this BT adapter it not works I tried WIN XP also WIN 8. The bluetooth connection is OK also drivers. I used the newest version of Multiecuscan 2.2 also the older one 1.4 and without success. When I tested the adapter by function in Multiecuscan it showed me that this adaper is not compatible with elm v1.3. This version is 2.1. I took some pictures. Have you allready seen this problem?
Greeting tuner182
- 20141204_094305.jpg (366.06 KiB) Viewed 6108 times
- 20141204_094314.jpg (368.82 KiB) Viewed 6108 times
Posted: 04 Dec 2014, 21:51
by wasuky
Hi there,
I'm new in the forum and as everyone here, i've got a question for you guys.
I just rebuilt the engine of my Daewoo Rezzo (is the same engine of the Suzuki Forenza) and decided to scan the ECU to check any error. I just got my bluetooth ELM327 and after a few hours of trying several softwares (including Android apps) the thing can't connect to the ECU. The software/app can read the devide, but can´t connect to the ECU.
I just read about the resistor R04, i opened my devide and found out that's quite different to the ones i've seen here.
I'm 100% new with all this OBD scan system, so I hope you can give me hand here.
I send my thanks in advance!!
Posted: 09 Dec 2014, 16:00
by Tony Evo
Hello guys , I have this elm 327 bluetooth Chinese works fine for the diagnosis engine , but does not work for the diagnosis of the CAN network , which changes I can make ?
https://www.dropbox.com/s/93n07taak7zsh ... 9.jpg?dl=0
https://www.dropbox.com/s/6k0yqy8zpbwx9 ... 2.jpg?dl=0
https://www.dropbox.com/s/xzt8t94uh1706 ... 8.jpg?dl=0
very thanks
