Post by Alfaeddy » 28 Apr 2016, 22:43
zhbrrjh wrote:Sorry for my English.
Fiat Panda 2008 dialogic (selespeed)
ELM 327 WI-FI USB
wires suitable for pin 2,4-5,6,7,9,14,16
reads transmission - gearbox, removes (delite) the error codes , but does not do service work on the clutch calibration torirovaniyu and other works , removes the error codes , but does not do service work on the clutch calibration torirovaniyu and other works.
How resistor should I remove
Thanks for help
https://drive.google.com/file/d/0BxHjrm ... sp=sharing
The CFC 228 is not read via the CAN bus protocol.
Therefore, it is not the problem a bridge resistance.
Your service is read via CAN Bus why this does not work
but very well be the connection to the instrument panel or Proxie Aligment
works I can not tell you.
On your board no bridge resistance is found
Mach nevertheless please times a screen of the interface test and add the one here
I think your problem is another, not a bridge resistance.
Post by Alfaeddy » 28 Apr 2016, 22:47
yonubear wrote:Hi all,
I am hoping you can help me out I am trying to get a elm327 working on JT850 PWM and I am having no luck I am hoping someone here may be able to help me out I am attaching photos of the PCB.
Thanks,
Yonu
Hello Yonu
You forgot here specify which vehicle or control you want to read?
Model?
Year?
Control?
nixdorf
Post by nixdorf » 02 May 2016, 15:10
Hello everybody.
I have an Fiat Grande Punto 1.3JTD 75hp and I have a little problem by connecting to the ECU.
The car is currently not starting and the MIL indicator is on.
I bought from ebay ELM327 1.5 (with the rest of the adapters needed).
The computer is running on windows XP all drivers are installed but when I go to the Settings--->Interface--->Interface type: ELM 327 1.3+ (BaudRate 38400) and click test It goes to COMMAND ATSPC - The operation has timed out.
Meanwhile the cable is connected to the vehicle and the computer (12v are going to the vehicle OBD connector).
Software timeout:
Cable pictures:
Any ideas how to fix it ?
senkyr
Post by senkyr » 02 May 2016, 17:01
Hello everybody,
I have this elm327 cable: Image
Can you help me how can I instal it in windows 10?
Thanks for your answers.
albert
Post by albert » 03 May 2016, 14:14
nixdorf wrote:Hello everybody.
Software timeout:
Cable pictures:
Exactly the same IF I have and exactly the same issue (and the same car).
I can set Interface type only manually .
AT USB commads are OK and the first AT OBD command fails.
nixdorf
Post by nixdorf » 03 May 2016, 19:55
Software timeout:
Cable pictures:
I have all ready bought another Interface obviously WE HAVE TO ask is the chip ft232 inside etc.. Anyway it will be really nice if we can find out fix for this one. I have a feeling that we should "play" with drivers really not sure. I will try the commands manually to see what is happening.
drunzy
Post by drunzy » 04 May 2016, 19:13
I have the same elm as the post above this post
when i test it says ok on the most things accept the last one i get a time out error
how can this be solved
the car i am trying to connect with is a Fiat Stilo 1,6 16v modelyear is 2005
I hope someone can help me
i really do need the cable to work because i own a STILO :lol: :lol: :lol:
greetz Drunzy
albert
Post by albert » 04 May 2016, 21:22
I'm almost sure it's not a driver issue since AT commands work fine for the USB part.
I manually installed at least 5 different drives and the only one that make this ELM working is CH340.
I attempt this with several PCs too.
I tried to look at the PCB tracks to see if there is a resistor between two pins of the obd connector (or between the i/o pins of the IC) but this PCB is really too small for my eyes and my hands.
(I have already bought another Interface too)
luka78
Post by luka78 » 05 May 2016, 15:33
I bought this one, hope it will work http://www.ebay.com/itm/151817014157
cengiz522
Post by cengiz522 » 06 May 2016, 07:15
hello friends how can I add pictures
