steph48
Post by steph48 » 20 Sep 2010, 19:14
And here ENGINE ECU:
Port ouvert par le processus "Multiecuscan2.exe" (PID: 4068)
Requête:19/09/2010 16:20:56.46264
 41 54 5A 0A 0D                                    ATZ..
Réponse:19/09/2010 16:20:56.52564 (+0.0625 seconds)
 41 54 5A 0A 0D 0D 0D 45 4C 4D 33 32 37 20 76 31   ATZ....ELM327 v1
 2E 35 61 0D 0D 3E                                 .5a..>
Requête:19/09/2010 16:20:57.40064 (+0.0156 seconds)
 41 54 45 30 0A 0D                                 ATE0..
Réponse:19/09/2010 16:20:57.44764 (+0.0469 seconds)
 41 54 45 30 0A 0D 4F 4B 0D 0D 3E                  ATE0..OK..>
Requête:19/09/2010 16:20:57.44764 (+0.0000 seconds)
 41 54 4C 30 0A 0D                                 ATL0..
Réponse:19/09/2010 16:20:57.50964 (+0.0625 seconds)
 4F 4B 0D 0D 3E                                    OK..>
Requête:19/09/2010 16:20:57.50964 (+0.0000 seconds)
 41 54 49 42 31 30 0A 0D                           ATIB10..
Réponse:19/09/2010 16:20:57.57264 (+0.0625 seconds)
Requête:19/09/2010 16:20:57.57264 (+0.0000 seconds)
 41 54 53 50 35 0A 0D                              ATSP5..
Réponse:19/09/2010 16:20:57.61964 (+0.0469 seconds)
Requête:19/09/2010 16:20:57.61964 (+0.0000 seconds)
 41 54 53 30 0A 0D                                 ATS0..
Réponse:19/09/2010 16:20:57.68164 (+0.0625 seconds)
 3F 0D 0D 3E                                       ?..>
Requête:19/09/2010 16:20:57.68164 (+0.0000 seconds)
 41 54 53 48 20 38 31 31 30 46 31 0A 0D            ATSH 8110F1..
Réponse:19/09/2010 16:20:58.74464 (+0.0625 seconds)
Requête:19/09/2010 16:20:58.74464 (+0.0000 seconds)
 31 41 39 37 0A 0D                                 1A97..
Réponse:19/09/2010 16:20:58.79064 (+0.0469 seconds)
 42 55 53 20 49 4E 49 54 3A 20 4F 4B 0D 35 41 20   BUS INIT: OK.5A
 39 37 20 46 44 20 38 36 20 42 39 20 30 34 20 31   97 FD 86 B9 04 1
 35 20 0D 0D 3E                                    5 ..>
Requête:19/09/2010 16:20:58.66564 (+0.0000 seconds)
 31 41 20 39 37 0A 0D                              1A 97..
Réponse:19/09/2010 16:20:59.83764 (+0.1719 seconds)
 35 41 20 39 37 20 46 44 20 38 36 20 42 39 20 30   5A 97 FD 86 B9 0
 34 20 31 35 20 0D 0D 3E                           4 15 ..>
Requête:19/09/2010 16:20:59.21264 (+0.0781 seconds)
 31 41 20 39 31 0A 0D                              1A 91..
Réponse:19/09/2010 16:20:59.41564 (+0.2031 seconds)
 35 41 20 39 31 20 33 35 20 33 35 20 33 32 20 33   5A 91 35 35 32 3
 30 20 33 32 20 33 37 20 33 30 20 33 30 20 32 30   0 32 37 30 30 20
 20 32 30 20 32 30 20 0D 0D 3E                      20 20 ..>
Requête:19/09/2010 16:20:59.71264 (+0.0000 seconds)
 31 41 20 39 32 0A 0D                              1A 92..
Réponse:19/09/2010 16:21:00.88464 (+0.1719 seconds)
 35 41 20 39 32 20 33 30 20 33 32 20 33 38 20 33   5A 92 30 32 38 3
 31 20 33 30 20 33 31 20 33 32 20 33 31 20 33 34   1 30 31 32 31 34
 20 33 38 20 32 30 20 0D 0D 3E                      38 20 ..>
Requête:19/09/2010 16:21:00.22864 (+0.0000 seconds)
 31 41 20 39 33 0A 0D                              1A 93..
Réponse:19/09/2010 16:21:00.40064 (+0.1719 seconds)
 35 41 20 39 33 20 30 30 20 0D 0D 3E               5A 93 00 ..>
Requête:19/09/2010 16:21:00.52564 (+0.0000 seconds)
 31 41 20 39 34 0A 0D                              1A 94..
Réponse:19/09/2010 16:21:00.69764 (+0.1719 seconds)
 35 41 20 39 34 20 33 31 20 33 30 20 33 33 20 33   5A 94 31 30 33 3
 37 20 33 33 20 33 37 20 33 35 20 33 38 20 33 34   7 33 37 35 38 34
 20 33 34 20 32 30 20 0D 0D 3E                      34 20 ..>
Requête:19/09/2010 16:21:01.93164 (+0.0000 seconds)
 31 41 20 39 35 0A 0D                              1A 95..
Réponse:19/09/2010 16:21:01.10364 (+0.1719 seconds)
 35 41 20 39 35 20 33 33 20 34 32 20 0D 0D 3E      5A 95 33 42 ..>
Requête:19/09/2010 16:21:01.21264 (+0.0000 seconds)
 31 41 20 39 36 0A 0D                              1A 96..
Réponse:19/09/2010 16:21:01.40064 (+0.1875 seconds)
 35 41 20 39 36 20 33 31 20 33 39 20 33 34 20 33   5A 96 31 39 34 3
 34 20 33 32 20 32 30 20 0D 0D 3E                  4 32 20 ..>
Requête:19/09/2010 16:21:01.57264 (+0.0000 seconds)
 31 41 20 39 39 0A 0D                              1A 99..
Réponse:19/09/2010 16:21:02.74464 (+0.1719 seconds)
 37 46 20 31 41 20 32 31 20 0D 0D 3E               7F 1A 21 ..>
Requête:19/09/2010 16:21:02.85364 (+0.0000 seconds)
Réponse:19/09/2010 16:21:02.02564 (+0.1719 seconds)
 35 41 20 39 39 20 32 30 20 30 35 20 30 35 20 31   5A 99 20 05 05 1
 33 20 0D 0D 3E                                    3 ..>
Requête:19/09/2010 16:21:03.22864 (+1.0313 seconds)
 33 45 0A 0D                                       3E..
Réponse:19/09/2010 16:21:03.41564 (+0.1875 seconds)
 37 45 20 0D 0D 3E                                 7E ..>
Post by yani » 23 Sep 2010, 05:39
@steph48
You don't have OK for all commands!
See ATS0 and ATCRA...
This means that your ELM is actually v1.2
JTD171
Post by JTD171 » 26 Sep 2010, 15:03
On the circiut board mine has version 1.2a but when the service reset was free it did that alright.
Post by s130 » 26 Sep 2010, 18:33
Depending on the make, the version number of the circuit board may not be a good guide.
I'm sure I have a version 1.2a PCB but with a genuide Elm V1.4 chip.
To my knowledge there were NO electrical circuit changes required to support either and Elm V1.2 or V1.4 chip.
This means that V1.2 PCB boards will be used with V1.4 chips still stock runs out. At this point I would reversion the PCB even if it were identical to the previous one.
mattydr67
Post by mattydr67 » 01 Oct 2010, 10:50
Yes that's right the circuit it is not so change but there one change.
In to the 1.2 PCB ( clones ) you must to make some changes to work on 34800 baud becasue it is seted just for 9600 baud. It can be fixed.
If you use a PCB for 1.3 to you can change the chip with an original ELM327 v1.4, because it is the same. Ok there is a small change in elm327 v1.4 PCB to reduce power.
ivica21
Post by ivica21 » 01 Oct 2010, 14:41
With this my 4 elm 327 finnaly works perfect.
Big THX 8-)
ELM327 v 1.4
dusan147
Post by dusan147 » 01 Oct 2010, 20:00
I have only one difficult with ELM327 1.3a: when I am connected with ECU in Multiecuscan 2.4.1 (key is in MAR position) and start the engine, FES immediately disconnect from ECU if in "Parameters section" some item is checked... In the case when engine starts and after that I perform connection between FES and ECU, all will be OK. Is it normal? Or I can to try change in my netbook device manager (interrupt adjustment, etc...)?
Being Merlin and not Arthur!
Post by yani » 02 Oct 2010, 08:39
That is normal behaviour for ELM interfaces. They are very sensitive to low power supply and disconnect immediately when the power supply voltage drops below 12V (this happens when starting the car).
sprint750
Post by sprint750 » 02 Oct 2010, 15:03
It was sold as ELM 327 1.4 'with a genuine ELM chip'. :?
Although the box looks the same,
PCB is quite different (named [b]'USB V3.0'[/b]) from the versions pictured on previous posts
(C14/C15)
Best regards
Sébastien
A pessimistic is a former optimistic who gathered experience
dusan147
Post by dusan147 » 02 Oct 2010, 15:56
It is OK if this behavior is normal, but this is uncomfortable for me.
Do you have some recommendations about hardware solution of this problem (additional power supply line, for example)?
Maybe will be helpful information that problem doesn't appear if I am connected and no items in "Parameters" section are selected...
