Gui6420
Post
by Gui6420 » 07 Nov 2017, 21:46
mrnixdorf wrote:hey guys,
any help with this interface i will appreciate it, i can only connect to ecu engine.
Thx
Hey guys,
I have the same device as the image above, and I am not able to do the proxy alignment
What vehicle? Fiat Bravo 1.4 tjet
What year? 2014
What control?
What driver was installed? Multiecuscan 3.6 or AlfaOBD
If anyone can help me!!
Thanks!
fxiat500
Post
by fxiat500 » 23 Nov 2017, 06:04
Finaly i bought an elm 327with pic 25k80 (lot of them advertise when you know you have to find it). Work fully test, error, scan and proxi alignment. It is with 64 bit windows on 2009 500c.
But I doubt multiecuscan have the convertible module option. Or this module have no proxyalignement and no way to test his function anyway ?
To find the 120ohm resistor between pin 6 and 14 well you test continuity between the pins and then resistor you suspect
xusete
Post
by xusete » 28 Nov 2017, 16:20
Hola!
I am trying to access to body in a alfa 147 1.6 twinspark 2004. I have an Elm327 wifi interface and can't find the famous 121ohms resistor I am supposed to remove.
Resistance between pins 6 and 14 is 50kohms (according to my multimeter).
Board is so so tiny!
- 20171128_171348.jpg (2.5 MiB) Viewed 16055 times
- 20171128_171358.jpg (2.37 MiB) Viewed 16055 times
rtfw61v2
Post
by rtfw61v2 » 29 Nov 2017, 15:52
Hi guys, i have just bought this elm327 clone from aliexpress, obviously cannot works with my Alfa Romeo 147 1.6 TS 16v. There are some inscriptions on the card "A-L07AJ_M", "M160421" and "M160413". I read that it was enough to remove some resistance to make it work properly. Can someone help me?
- 20171129_161439.jpg (2.94 MiB) Viewed 16047 times
- 20171129_161400.jpg (3.16 MiB) Viewed 16047 times
- 20171129_161609.jpg (2.96 MiB) Viewed 16047 times
PatrickH
Post
by PatrickH » 07 Dec 2017, 02:22
[attachment=0]index.jpg[/attachment]
Fiat Punto mk2
First registrated in 2000
1.2 8v ISO9141-2
Tryed Torque, AlfaOBD on Android and Car Scanner on Windowsphone. Car Scanner trows out a Warning "Bad ELM Clone"
, Torque sticks in a loop trying to find "Model".
Someones got this one running?
- index.jpg (172.77 KiB) Viewed 15985 times
Matevz251083
Post
by Matevz251083 » 13 Dec 2017, 18:34
Hello All I am Matevz from Slovenia, Ljubljana. I have bought this elm, it says V1.5a but no labels inside. What resistor do I remove? It connects bosch electronics in alfa 159 but then nothing so I need to remove resistor. I havent seen such elm hire.
Thank you for your help!
- elm.jpg (460.31 KiB) Viewed 15904 times
Matevz251083
Post
by Matevz251083 » 13 Dec 2017, 22:27
Hello me again, is this the rigt resistor to remove? pins 6 and 14 comes out where its marked and then they share this r7 resistor. Do I remove it? I think so. Thank you! Sorry for bad picture.
- IMG_1475.jpg (1.39 MiB) Viewed 15900 times
Matevz251083
Post
by Matevz251083 » 14 Dec 2017, 10:32
Hello I have uploaded pictures where pin 6 and 14 goes to R07 but they didnt post them. So I think its R07 to remove. Am I right?
Tnx
Matevz251083
Post
by Matevz251083 » 17 Dec 2017, 21:18
Well I ordered another one this time modified for alfa from german seller.You dont know what you get from china...No response hire, just i dont know would be fine...
Sbt74
Post
by Sbt74 » 31 Dec 2017, 15:10
Hello to all
I am new at this forum and would like to thank you all for all the information you are puting here.
I have bought elm327 (becouse of info on this forum) but i can’t find any like mine. Can anybody help me with this one? Do i need also replace anything or remove?
Thank you
- 85D59992-CF3F-4BFE-A623-C8F512DDD27A.jpeg (1.88 MiB) Viewed 14179 times
- 821826D0-82DC-4A13-9182-B69C19E67FD3.jpeg (1.91 MiB) Viewed 14179 times
- 764F11DE-F60B-49FF-97D6-3A5EE90C43BC.jpeg (1.94 MiB) Viewed 14179 times
