Post by Alfaeddy » 08 Apr 2013, 16:14
Take a update to Multiecuscan because there was an earlier version
times also made ​​one of the problems.
But first you need to have a functional interface.
Boris
Post by Boris » 12 Apr 2013, 12:17
I have bought another interface (WiFi and USB combined, I already have Bluetooth and USB) and as predicted, CAN does not work.
Please can you help, what resistor to remove?
Boris
Post by Boris » 12 Apr 2013, 12:20
More pics:
Post by Alfaeddy » 12 Apr 2013, 15:33
Hello Boris
Great pictures but it's hard to read the label on the components
But if I am not mistaken you have to remove R6 (red Frame )
P4126238 markiert.jpg (1.07 MiB) Viewed 4674 times
Boris
Post by Boris » 12 Apr 2013, 16:45
Are you sure, or I will take the picture again. Which picture/component you need to read?
Post by Alfaeddy » 12 Apr 2013, 16:50
Yes I'm 95% sure, but doing is another picture of the part with 8 pins in addition to the resistor in the red frame
lolo85v
Post by lolo85v » 12 Apr 2013, 18:13
Hello I have an elm case metal 1.5 I has do not arrive has to make reset service(department) it has the resistance r4 (272) there if I remove(kidnap) him(it) it is similar what(who) resistance needs that I remove(kidnap)? THANK YOU
http://i74.servimg.com/u/f74/13/84/33/82/20130419.jpg
Post by Alfaeddy » 12 Apr 2013, 18:28
Hello lolo85v
This interface we had more times described here
Your picture is very bad
I see no labels
But as far as I Know it must not be changed at this interface.
Which vehicle you would like to read it?
lolo85v
Post by lolo85v » 12 Apr 2013, 18:42
ALFA 159
lolo85v
Post by lolo85v » 12 Apr 2013, 18:47
An other one embellishes with images
http://i74.servimg.com/u/f74/13/84/33/82/20130420.jpg
