running diagnostic on free rev - Alfa GT
portbhoy
Post by portbhoy » 05 Jul 2010, 21:34
Hi, i need to verify my MAF is dead, can this be checked on my 2005 Alfa GT 1.8 TS using the free version? when i connected earier i get a message saying that a registered version must be used/ thanks in advance
oem
Re: running diagnostic on free rev - Alfa GT
Post by oem » 06 Jul 2010, 06:24
When the engine is at maximum speed (rpm limiter and full throttle), maf sensor should consider 408 kg / h air.
O.E.Motorsport - tuning & innovation
portbhoy
Post by portbhoy » 06 Jul 2010, 08:14
oem wrote:When the engine is at maximum speed (rpm limiter and full throttle), maf sensor should consider 408 kg / h air.
Thanks, but can i check this using the free version?
oem
Post by oem » 06 Jul 2010, 12:16
Yes, you can. You must see the Air Quantity in real time. Air Quantity on 7000 rpm must be 408 kg/h
