Hi Eddy,
unfortunately I can not unsolder the board, but the photos I sent you do see it in all angles.
The only resistors under the board are: R5 (473 ohms), R6 (103), R7 (103), R16 (102), R17 (102).
It could be r5?
It could be r5?
Hi Eddy
Too bad, maybe I can take some pictures of the users from the other forum.
let's see
R5 can not be
If a bridge resistor is present, the imprinted 121 or 1200
But I can think of another
measure times with a multimeter between pin 6 and pin 14 the Ohm value
So you can test whether a bridge resistor is present.
let's see
R5 can not be
I measured between pin 6 and pin 14 , and indeed the value is 120 ohms. so there is resistor . now we have to find the bastard resistor
Greetings
Greetings
Hi Eddy
Comparisons times the interface in the image with your
in this I marked the bridge resistor.
What imprint has the resistance in your
ELM Interface ??
Edit:
Look on page 144 there is the same board as in your interface
ELM Interface ??
Edit:
Hello Eddy,
unfortunately there is not that resistor in my interface
I have found that there are resistors under the tab at the bottom ( as I indicated in the figure) , where they attack the 16-pin ! how can I get them ? come off the 16 pin from the plastic ?
Greetings
Greetings
I solved it! The resistor was under, and not to unsolder everything I removed the plastic under the pin to access it and I removed the resistor. Now everything works perfectly! Eddy Thanks for the advice.
Greetings.
Greetings.
Hello Alfaeddy
Can you help me with this interface, please? Which resistor should I remove? Thank you.
- 20141025024700218.jpg (654.13 KiB) Viewed 4284 times
- 20141025024908630.jpg (716.96 KiB) Viewed 4284 times
hello
Remove the white (8 times) plug housing
And make a picture of it
Which vehicle ???
Which vehicle ???
My car is Fiat Punto mk2 1.2 16v 2000.
- IMG_20141026_225613.jpg (562.96 KiB) Viewed 4254 times
