I have the following question:
In the list of the SUPPORTED VEHICLES/SYSTEMS I can see, that for the Fiat
Ducato (type 250) Facelift the Tire Pressure Control (TPMS) Schrader (2/3 axle) is not supported.
Is there a chance that this feature will be implemented in the next Version of the “Multiecuscan” program?
The Version 4.8 I have already bought.
Gerd
Re: Ducato (type 250) Facelift
Unfortunately, the Ducato Facelift was not included in version 4.8 of Multiecusan.
Hi!
In MES is 3 versions of Ducato
1 - X250 2006-2009 with white BCM - without adapters
2 - X250FL (means facelift) 2010-2014 same body as X250 but with black BCM - with yellow adapter
3 - X290 body facelift 2014+ with black BCM - with yellow adapter
Newest ducato8 or X295 2021+ is unsupported yet but you can connect to BCM as Fiat TIPO... Proxialignment procedure is on your own risk...
Hallo Chrener, many thanks for your hint.
But with my equipment I can’t access to Tipo. I have MES 4.9, EML 327 Interface and the yellow adapter.
Furthermore I wanted to change the value in the Tire Pressure Control and in the list of supported vehicles in non Tipo with a Tire Pressure Control.
I have actually same problem, with MES 4.9 and CANtieCar don't have access to a Ducato (with Pössl Caravan) ECU's.
On our Fiat 500e (California) everything is working fine
