Gearbox change
Posted: 24 Feb 2021, 09:33
by abuk8
Hello, I have a problem with my cruisecontroll. Previous owner swap the gearbox (Grande Punto 1.9 120HP) from the 130HP engine. And because of this i cant use my cruise controll. It would be great to have the possibilities to change gear ratio or gearbox. Thanks.
Re: Gearbox change
Posted: 24 Feb 2021, 15:08
by shpuncik
this is beyond MES scope. you need to make changes in engine ecu software for right gear ratios. find who specialize in engine tuning - they should be able to sort this out.
Re: Gearbox change
Posted: 21 Feb 2022, 21:57
by abuk8
shpuncik wrote:
24 Feb 2021, 15:08
I found in 4.8 MES in proxy alignment posibilitty of gearbox cahange there is manual, selspeed, ddct, automatic and then type 5,6..etc. Do you think that this could be solution?
Re: Gearbox change
Posted: 23 Feb 2022, 16:59
by abarthmultijet
I think it could be a solution, first save the proxy code (control-alt-C when in the proxy allignment tab) to windows notepad. Then try the different gearbox type's.
Re: Gearbox change
Posted: 07 Mar 2022, 19:42
by chrener
You need to change "final Ratio"
Re: Gearbox change
Posted: 31 Mar 2022, 21:01
by Jo_Neu
Hi, i have the same Problem with Ducato Multijet 180 from 2013.......
How can i change the points of Gearbox??
Thx
Re: Gearbox change
Posted: 01 Apr 2022, 18:10
by Jo_Neu
abuk8 wrote:
21 Feb 2022, 21:57
shpuncik wrote:
24 Feb 2021, 15:08
Hi, do you have tested it?
This will be very interest
Re: Gearbox change
Posted: 19 Mar 2023, 21:15
by abuk8
Jo_Neu wrote:
01 Apr 2022, 18:10
abuk8 wrote:
21 Feb 2022, 21:57
shpuncik wrote:
24 Feb 2021, 15:08
No i try just free version. I dont want to destroy it
Posted: 03 Mar 2024, 00:40
by BBOinsam
Thanks but I kinda dont know how to change that. I was looking through all the skins in bitmap and couldnt find anything. I might have to add my own?
