Fiat 500L 1.3MJ EUR6W (9/2017)
kimme1024
Post by kimme1024 » 16 Dec 2020, 14:43
I have de registered version of MES.
I'm trying to do a service reset on a FIAT 500L (9/2017).
I connected it with the yellow adapter as MES asks me to do but I can't connect to the service module.
When I try to select a 500X I can read the all the data but can't execute the reset.
As it is possible to read the data via the 500X menu I guess that the issue exists on the MES side instead of the car side.
Any help would be greatly appreciated!
Kindest regards,
Kim
alex-et3
Re: Fiat 500L 1.3MJ EUR6W (9/2017)
Post by alex-et3 » 16 Dec 2020, 21:26
your car has the sgw control unit, so you can only check the parameters. if you want to reset or activate you need the sgw bypass.
