Page 1 of 2
Alfa Giulia 952 disable auto start/stop
Posted: 23 Nov 2018, 09:28
by jwq
It would be great if it would be possible to permanently disable the auto start/stop feature on the Giulia/Stelvio ....
Re: Alfa Giulia 952 disable auto start/stop
Posted: 15 Jul 2020, 06:54
by fasda1984
same request here, any solution?
Posted: 20 Jul 2020, 12:29
by fasda1984
i'm trying to change my country to USA, in EU country is not permitted, if it work i contact you
Posted: 21 Jul 2020, 12:15
by fasda1984
No, don’t work changing country. Need new feature from multiecuscan update to disabile stop/start in Giulia 952
Posted: 21 Jul 2020, 13:19
by verrilli
You can buy a device from stuff4car.com to disable the start/stop
Posted: 14 Oct 2020, 09:15
by Don Tomaso
This would be great to use MES to disable Start/ Stop.
Hope this feature will be added. Or maybe its hidden somewhere in the MES?
Posted: 06 Nov 2020, 21:31
by bowdenandymecom
STOP/START on the Giulia generally stops working of its own accord as the IBS rarely gets the battery state of charge above the threshold below which S/S is disabled.
Failing that the stuff4car device can be relied upon.
Posted: 24 Feb 2021, 07:54
by GenTLe
It is possible on AlfaODB software.
It would be great if the SW engineer behind MES could check what AlfaODB does and reproduce it on MES too. Most probably it's some proxy bit to be changed.
Posted: 02 May 2021, 19:23
by BoDukeDave
Same request here
Posted: 16 Feb 2022, 22:23
by zapdus
I solved this
On fiat punto evo same thing, start stop off and not starting
I enabled it again and disabled start stop on engine ecu file
