Enable TCT steering wheels paddles
Posted: 31 Jan 2017, 21:33
by federicoco
I bought a MY2014 steering wheel with TCT Paddle
All radio and blue&me works fine but paddle dons't work
is possible to enable this feature? which kind of steering wheel i need to set? 10 commands instead of 8?
thank you
Federico
Re: Enable TCT steering wheels paddles
Posted: 06 Feb 2017, 18:27
by thembalu
I am also interested.
Posted: 17 Feb 2017, 08:13
by yani
What make/model/year is the car?
Posted: 18 Feb 2017, 11:35
by thembalu
Hallo
Giulietta, 2011. 2.0jtdm, tct
Posted: 19 Feb 2017, 12:26
by yani
You can try the following:
1. Connect to your car with CAN Setup/PROXI Alignment and go to Adjustments
2. press ctrl+alt+c from the keyboard- Multiecuscan will open a window with title “Custom PROXI”
3. change byte 80 as follows:
-if it is 00 then change it to 20
-if it is 01 then change it to 21
-if it is 03 then change it to 23
-if it is 10 then change it to 30
-if it is 11 then change it to 31
-if it is 13 then change it to 33
BE VERY CAREFUL NOT TO CHANGE OR DELETE ANYTHING ELSE!!!
4. Click OK
5. Execute PROXI ALIGNMENT PROCEDURE
6. Switch OFF the car and wait 1 minute.
Re-start the car and check if paddles are activated…
