Support for 500X 1.4l 140BHP Turbo MultiAir II
Post by s130 » 06 Aug 2015, 13:44
Please can you put the Fiat 500X Cross Plus 1.4 MultiAir II on your todo list.
dziadzia1982
Re: Support for 500X 1.4l 140BHP Turbo MultiAir II
Post by dziadzia1982 » 26 Aug 2015, 19:26
s130 wrote:Please can you put the Fiat 500X Cross Plus 1.4 MultiAir II on your todo list.
The controller has used Bosch ME 17.3.0. It occurs in Mito and Giulietta TB 135 120 drivers installed from 2013 that meet Euro 6. The program multiecuscan does not develop at all
Post by s130 » 26 Aug 2015, 20:56
Thanks for the feedback.
What I think you are saying is that the 500X 1.4l MultiAir II ECU uses the Bosch ME 17.3.0 ECU and MultiECUScan does not currently support this ECU. Also there are obviously other nodes (ABS, AirCon, etc. , etc that may or may not be used on other currently supported models.
I did, a long while ago, ask for a node to ISO code cross reference table so that even if MES doesn't list Model Fiat XXX you could use the Scan function to identify the various unit/node ISO codes and then find/select an MES listed model that already supports that unit.
This is a current valid MES criticism/development issue. I would like to be able to connect to any specific supported node/module ISO code without having to select a particular vehicle. Adding this functionality would enable shared common ECUs/Nodes to be accessed independently of vehicle model selection.
The easiest solution to this is for MES to publish/support a cross reference table so that if my new Fiat 900X has ECU xyz I could locate another model, say Fiat 800Z, that has that same id number and I could select the 800Z model to connect to the ECU on my 900X.
I'm willing to create / support such a cross reference table but I would need all the relevant ECU ISO codes to do so.
dziadzia1982
Post by dziadzia1982 » 31 Aug 2015, 13:50
Alfa Romeo Giulietta 1,4 TB 120 km EURO 6 2014 year
ECU Bosch ME 17.3.0
ECU ISO Code: 7C 86 F7 8C DA
xantus884
Post by xantus884 » 13 Dec 2015, 21:31
hi, 500x 1.6 multijet II will be supported? When?
Post by s130 » 14 Dec 2015, 19:09
I'm fairly sure MES Development have noted our requests and my model independent ECU connection ability suggestion.
I guess we just have to be patient while the development wheels churn! :)
