Lancia Ypsilon 2013/2014 Proxi ESP and Belt signal
pavllo1980
Post by pavllo1980 » 07 Jul 2014, 11:12
I would ask you if you can add in the Proxi Alignment Procedure for this model the ESP (ESC) function. I will to replace ABS with ESP (I did it in Nuova Bravo without Problems with FES but the functionality was/is in the program). It is possible ?
And the second thing, i would like turn off the belt signal...
Re: Lancia Ypsilon 2013/2014 Proxi ESP and Belt signal
Post by alfa156sarajevo » 07 Aug 2014, 22:05
I do not know answers of you questions but here is just one info which you can think about.
When you put ABS ECU with ESP function, I think, but I am not 100% sure, that you will need to change also steering angle sensor.
Some models of steering angle sensors have option with or without ESP function...
Bravo Nuova is higher class from Lancia Ypsilon.
pavllo1980
Post by pavllo1980 » 22 Aug 2014, 10:10
yes, you are probably right, but to do this upgrade I have to be sure, that this option is in the program (proxi- change from ABS to VDC)
pavllo1980
Post by pavllo1980 » 19 May 2015, 12:28
thanks to your program I added to my New Ypsilon Cruise Control , Fog Lights and the Radio buttons on steering wheel...Now I am looking for parts for Blue&me and It would be great If you could add this proxy procedure to activate ESP in new Ypsilon...
