Grande Punto Requests
TomJL
Post by TomJL » 12 Sep 2011, 16:05
I know this was mentioned in the general section but thought i would create a request:
- Can you activate the auto lights when you Lock/Unlock the car? Would also be very usefull if the follow you home lights would activate automatically when you turn the car off with the lights on.
- Is it possible to activate the auto open/close windows when holding down the lock/unlock on the car key for the GP?
- Is it possible to stop the warning message when you have the EGR Blanked/unplugged on the MJET?
I haven't yet purchased the full version but will do if it would help with investigating any of the above :D (Also I'm sure lots of GP owners would be very interested ;) )
Cheers,
Tom
Re: Grande Punto Requests
Post by yani » 12 Sep 2011, 16:29
If you are talking about flashing of the direction lights when you lock/unlock the car... then yes, I'm working on this feature.
"Follow me home" lights have specific functionality which cannot be changed.
This is not possible yet, but I'm working on feature, too.
No, this is only possible by reprogramming the ECU.
EnIgMa
Post by EnIgMa » 12 Sep 2011, 17:59
What do you guys mean as "flashing of the direction lights"?
Stock cars already blinks when opened or closed.
TomJL
Post by TomJL » 12 Sep 2011, 18:02
I'm not sure the correct name, courtesy lights? When the side-lights light up as you unlock the car, thank you for responding, look forward to the developments :)
Cheers,
Tom
Post by yani » 12 Sep 2011, 18:59
EnIgMa wrote:What do you guys mean as "flashing of the direction lights"?
Maybe it is disabled on some cars...
EnIgMa
Post by EnIgMa » 12 Sep 2011, 20:50
Sorry, didn't thought about that :oops:
Anyway, I also thought you already did this.
It is under "Body Computer" module, then "Adjustments", then "Indicators Command" (Alarm Mode too where required), isn't it?
off course, only where supported.
steedy27
Post by steedy27 » 12 Sep 2011, 21:28
yani wrote:Hi,
Think he means when you open the car from locked the front and rear lights like follow me home automatically come on.
Also can ECU scan be able to turn of the beeping when the seatbelts are not connected while driving - or a higher speed till it starts beeping?
EnIgMa
Post by EnIgMa » 12 Sep 2011, 21:35
you can already turn off the buzz.
steedy27
Post by steedy27 » 12 Sep 2011, 21:45
EnIgMa wrote:you can already turn off the buzz.
Thanks is there a user guide on how to do this?
Post by yani » 13 Sep 2011, 05:14
EnIgMa wrote: Anyway, I also thought you already did this.
You are completely right... it is already there in Multiecuscan 3.2.
