Hi Yani,
can we have the support in FES for the car above?I've tried to connect FES with the "Grande Punto 1.4 16v Abarth" aleady persent in the current version of FES but some parameter ( such as "odometer" ) don't work correctly. Thank You
Grande Punto Abarth "essesse" 180cv
Re: Grande Punto Abarth "essesse" 180cv
What is the ISO code of the ECU?
You should choose Grande Punto 1.4 TURBO 16V not 1.4 16V. Abarth has an T-Jet engine, not a Star-Jet one.
i'm sorry, where i can read the ISO code?yani wrote:What is the ISO code of the ECU?
i know i know, but maybe "normal" ECU of the Grande Punto Abarth (155cv) in a little bit different with thw Grande Punto Abarth "essesse" (180cv)tzok wrote:You should choose Grande Punto 1.4 TURBO 16V not 1.4 16V. Abarth has an T-Jet engine, not a Star-Jet one.
Just connect to your engine and read the ISO Code from the "Info" window of Multiecuscan (it appears right after you connect to the ECU).A. Mugnano wrote: i'm sorry, where i can read the ISO code?
Or, you can click the "Scan" button and Multiecuscan will scan your car and give you the ISO codes of all modules in it.
oh okok it's simple......as soon as possible will post the ISO code,Thanksyani wrote:Just connect to your engine and read the ISO Code from the "Info" window of Multiecuscan (it appears right after you connect to the ECU).A. Mugnano wrote: i'm sorry, where i can read the ISO code?
ECU ISO Code: 7C 86 54 07 32
05/04/2011 18:23:03
CONNECTED TO:
FIAT GRANDE PUNTO ABARTH 1.4 TURBO 16V
Bosch Motronic Me7.9.10 CF5/EOBD Injection (1.4 16V)
05/04/2011 18:23:03
CONNECTED TO:
According to this ISO code the type of ECU is correct. It is Bosch Motronic Me7.9.10 CF5/EOBD Injection.
So, it should show correct data.
Is there any other parameter (except the Odometer) which doesn't seem correct?
ok.....soon i can try to check other parameters and see if they work correctly.thank you
