Error logs as a part of parameters logs?
Posted: 05 Jan 2011, 21:29
by dusan147
Could you embed in future version of FES some type of error logs together with parameters logs? You can put this log column right to the TAG column in CSV format file... Is it complicated?
In that case we will can trace change of common parameters (boost, speed, airflow) and detect type and time of error appearance.
Re: Error logs as a part of parameters logs?
Posted: 05 Jan 2011, 22:23
by yani
Sounds like a good idea....
Although reading of the errors takes time and will reduce the recording speed.
I'll think how to implement this.
Thanks.
Posted: 06 Jan 2011, 06:39
by dusan147
Thank you in advance for the enthusiasm to try implementation of this very useful option...
In tuning trial/error activities, very often need is to locate time when error appears and to try connect some type of error with other parameters... If this error recording needs more time, than user of FES can decrease number of other parameters for trace?
Best regards from Dusan.
