How about ECU re-image (mapping)
Argo
Post by Argo » 13 Dec 2010, 19:31
I think Examiner can do this so why shouldn't Multiecuscan :idea:
Of course, finding good maps would be another issue.
wilco1v
Re: How about ECU re-image (mapping)
Post by wilco1v » 13 Dec 2010, 21:53
Read original ecu map would be fine
share original and remap (good/perfect-tuned file ) would be nice
share now how do it good (once and for all), more than nice
will it give immo problems ???
and how will ..... react if the car won,t run annymore ???
still atractive feature ;)
tomsa
Post by tomsa » 16 Dec 2010, 10:59
For remapping you must have a tool to read the ecu eeprom such as EOBD1260 which you can buy in the bay. Then you have to modify the Maps and write back the bin-file to the ECU with the tool I mentioned above. For my car (Alfa 159 EDC16/CF4) it works perfect.
bye
Tom
Alfa 159 JTDm +360Nm@2000rpm+EGR shutt-off+Regeneration off
http://tomsa.bplaced.net
http://www.facebook.com/pages/My159/176949985681507
wilco1v
Post by wilco1v » 19 Dec 2010, 12:55
yes i have eobd programmer (galletto clone ) reading yes ,programming not done (iaw5nf 1.6 16v stilo)
can you show you,r map org and mod
how did you handle immo??
(anyone out there who now to do programming/boot modus on iaw5nf ?? )
tomsa
Post by tomsa » 19 Dec 2010, 17:29
Hi, I do not know iaw5nf. I know only the diesel ECUs EDC16 EDC17. Here you download the file from the ECU, do your remapping and flash back the modified file. The immo code stored in the original file won't be touched. Maybe you should look around at chiptuners.org or so to find out about iaw5nf.
bye
