Fiat 500x electric park break
159sportwagon
Post by 159sportwagon » 28 Dec 2017, 19:11
Hello Yani, it is possible to work on el. Park break . Can I open the pistons from the rear break with mes for change the break pads.
Kind regards Pietro
Pandadance
Re: Fiat 500x electric park break
Post by Pandadance » 28 Dec 2017, 21:17
yes
m.brignoli83
Post by m.brignoli83 » 24 Sep 2018, 12:45
I need brake pad replacement procedure.
Someone can help me please.
There are many options on mes.
First time need to unlock brake and second time need to lock brake.
Wich is the correct procedure?
robert61
Post by robert61 » 24 Sep 2018, 20:57
REMOVING
- Put the car on the lift
1. Remove the retaining clip and release the brake fluid pipe.
2. Release the parking brake wiring.
3. By applying counter-torque to the nut (1a), undo the lower screws (1b) fixing the brake calliper
- Remove all traces of glue from the side tabs and on the brake calliper piston.
Avoid using degreasing agents that are not compatible with the rubber parts of the brake calliper.
Turn the calliper and remove the brake pads.
Remove the sliding clips.
REFITTING
- Clean the sliding clip housings on the bracket.
- Fit the new sliding clip on the bracket.
Place the brake pads in their housings.
The shoe on piston side (inner vehicle) is provided with a blade for indicating wear. The letter “B” indicates the ends for fixing the sliding clips.
The outer vehicle shoe has letters “A” printed on the ends for fixing the sliding clips.
Connect the diagnostic equipment to the diagnostic socket and go to “BSM/EPB control module”. Go to the “actuators” menu and start the “maintenance mode” procedure.
Start the “brake calliper piston retraction” procedure.
After fitting the brake calliper, start the “electric parking brake assembly check” procedure.
Using the pneumatic tool (1a), retract the cylinder (1b) of the rear brake calliper.
Put the brake calliper back in its housing applying reaction to the nut and tighten the new lower screw to the prescribed torque fastening it to the bracket.
- Engage the parking brake wiring.
- Engage the brake fluid pipe with the retaining clip.
Remove the car from the lift. :lol:
m.brignoli83
Post by m.brignoli83 » 26 Oct 2018, 00:28
:D
I want only know mes procedure for unlock rear brake for change pads and than procedure for activate brake again.
Post by s130 » 26 Oct 2018, 09:33
With MES then connect to the ABS system.
Then goto Adjustments [F7]
The you will find:
"EPB maintenance mode"
and
"Exit EPB maintenance mode"
m.brignoli83
Post by m.brignoli83 » 26 Oct 2018, 10:37
Thank you
