bug 5.0
Posted: 16 Sep 2022, 21:10
by DANIELE
this versine on alfaromeo giulia does not terminate correctly proxy on abs, ipc.
tested only on one car, in the next few days I will test on other cars and send a report. for now fixed with version 4.9
Re: bug 5.0
Posted: 16 Oct 2022, 08:27
by chrener
Same problem with proxi alignment on Stelvio MY2021
PROXI ALIGNMENT PROCEDURE
Writing to module: Engine Control Node (ECM/NCM) SUCCESS!
Writing to module: Automatic Transmission Node (TCM/NCA/NCR) SUCCESS!
Writing to module: Telematic Box Node (TBM) FAILED! - Timeout error
Writing to module: Driver Assistant System Node (DASM) FAILED! - Timeout error
Writing to module: Radio Frequency Hub Node (RFHM) FAILED! - Timeout error
Writing to module: Drive Train Control Node (DTCM) FAILED! - Timeout error
Writing to module: Entertainment Telematic Node (ETM) SUCCESS!
Writing to module: Amplifier Node (AMP) SUCCESS!
Writing to module: Comfort Seat and Wheel Node (CSWM) SUCCESS!
Writing to module: Left Blind Spot Sensor Node (LBSS) SUCCESS!
Writing to module: Right Blind Spot Sensor Node (RBSS) SUCCESS!
Writing to module: Entertainment multimedia control module (EMCM) SUCCESS!
Writing to module: Engine sound enhacement module (ESEM/ANC) SUCCESS!
Writing to module: Electric Steering Node (EPS/NGE) SUCCESS!
Writing to module: Brake System Node (ABS/BSM/NFR) SUCCESS!
Writing to module: Parking Sensor Node (PAM/NSP) SUCCESS!
Writing to module: Self-adaptive Headlamps Node (AFLS/NFA) SUCCESS!
Writing to module: Haptical Lane Feedback Node (HALF) SUCCESS!
Re: bug 5.0
Posted: 22 Oct 2022, 14:44
by Garagem
Dear,
I don't know if it would be exactly in this topic, but...
in Version 5.0 I tried to connect Cantiecar via Wifi and in the field to select the interface, the WIFI selection is with address 10.1
where the correct one would be 10.10.1.1, I could not make this change to test the functions via Wi-Fi
