Fiat 500x Proxy fails
Choconinja
Post by Choconinja » 06 Oct 2019, 14:51
I have a fiat 500x from 2017. I changed the oem radio for an Android radio from joying. Now the mileage indicator always flashes. I read in the forums that a proxy alligment should help here, but it fails.
The wired adapter elm is from electronic-fuchs.de including adapter 5 and 6.
The connection has no errors. But the proxy fails and the kilometer display still flashes.
What can I do?
CAN CONFIGURATION DATA:
4F 0C 40 05 10 00 01 00 0A 00 00 00 00 00 00 00 4F 0C 40 05 10 00 01 00 0A 00 00 00 00 00 00 00 01 08 00 00 00 00 00 00 08 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4F 0C 40 05 10 00 01 00 0A 00 00 00 00 00 00 00 4F 0C 40 05 10 00 01 00 0A 00 00 00 00 00 00 00 4F 0C 40 05 10 00 01 00 0A 00 00 00 00 00 00 00 4F 0C 40 05 10 00 01 00 0A 00 00 00 00 00 00 00 4F 0C 40 05 00 00 01 00 0A 00 00 00 00 00 00 00 33 38 33 33 34 30 34 31 30 37 32 4F 55 54 50 55 54 2D 53 49 54 20 17 01 16 4F 0C 40 05 10 00 01 00 0A 00 00 00 00 00 00 00 4F 0C 40 05 10 00 01 00 0A 00 00 00 00 00 00 00 D1 EA 1D 01 AD 81 07 E2 40 27 09 07 40 10 10 03 A3 1E 44 92 01 35 73 14 01 4F 03 34 00 B3 AC 01 4A 4B 07 00 8A 02 10 EE 00 00 20 04 00 01 03 54 FA 08 06 A5 00 42 00 01 8A 12 3D 40 00 01 03 C1 00 15 34 11 00 00 49 02 81 14 5B 42 04 00 00 33 AA 99 71 20 80 00 86 00 00 00 01 00 00 00 00 00 00 00 00 00 10 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
(Multiecuscan 4.4) 27.09.2019 14:20:03 Fiat 500X 1.4 16V T-Jet/MultiAir CAN Setup / PROXI Alignment Procedure (334)
Body Computer (BCM/NBC) EOL Ok
Motorsteuerung (ECM/NCM) EOL Ok
Instrumententafel (IPC/NQS)
EOL Ok Automatikgetriebe (TCM/NCA/NCR) EOL Ok
Knoten Getriebewählschalter (ESM/GSM/NSC) EOL Ok
Radio Frequency Hub Node (RFHM) EOL Ok
Drive Train Control Node (DTCM) EOL Ok
Klimaanlage (HVAC/NCL) EOL Ok
Entertainment Telematic Node (ETM) EOL Fehler - Timeout error
Comfort Seat and Wheel Node (CSWM) EOL Ok
Elektrische Lenkung (EPS/NGE) EOL Ok
Bremsanlage (ABS/BSM/NFR) EOL Ok
Knoten Parksensor (PAM/NSP) EOL Ok
Knoten Airbag (NAB/ORC) EOL Ok
Re: Fiat 500x Proxy fails
Post by s130 » 06 Oct 2019, 17:36
I'm not saying that this is your issue but but it may be due to your ELMs link speed and buffering.
I had an issue (some time ago) where Yani confirmed that 500X/Renegade vehicles had an issues with Proxi.
Originally ELM devices ran at a fixed speed too slow for Proxi on 500X/Renegade. However OBDLINK was faster "out of the box". I worked with Yani and tried OBDLINK and all was OK. Then Yani sent me some test code that would switch some/new ELM devices to a higher operating speed. This worked OK for me.
My suggestion is that you select the highest ELM operating speed offered in the MES settings.
Choconinja
Post by Choconinja » 10 Oct 2019, 15:01
is it this adapter?
https://www.amazon.com/ScanTool-425801-OBDLink-USB-Diagnostic/dp/B005ZWM0R4/ref=pd_sim_auto_3?ie=UTF8&refRID=1EMGMTWBYKCR62ACW5PM&tag=scantonet-20
Post by s130 » 11 Oct 2019, 16:16
Yes that is the one, as long as it is a genuine OBDLink unit, which I think it is. You can double check on the OBDLink website.
http://www.obdlink.com/sxusb/
arma500x
Post by arma500x » 05 Mar 2020, 07:51
buon giorno ho visto che nei bit postati ce un errore metto i miei bit 500x 4x4 italiano con kiles a me non funzionano le porte usb ho attivato uconnect 7 ma usb non vanno
33 38 33 33 34 30 31 32 34 37 33 4F 55 54 50 55 54 2D 53 49 54 20 16 03 15 4F 04 20 45 10 00 00 00 0A 00 00 00 00 00 00 00 4F 04 20 45 10 00 00 00 0A 00 00 00 00 00 00 00 D1 FA 0E 02 AC 82 07 E2 60 27 89 07 40 10 10 03 A3 28 64 92 01 35 73 14 01 4F 03 34 01 B3 A8 01 47 4B 07 00 A6 00 0E F9 00 00 10 01 00 05 13 54 91 64 02 AD 00 54 00 01 8A 15 3D 40 00 01 03 C5 00 D5 24 10 08 00 49 02 81 14 7B 42 80 00 00 9B AA 97 41 20 80 80 86 00 00 01 00 00 00 00 00 00 00 00 01 01 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -254 bit---4x4 ita cambio manuale kiles uconnect 7 non vanno le porte usb
arma500x
Post by arma500x » 05 Mar 2020, 07:57
33 38 33 33 34 30 34 36 37 33 36 4F 55 54 50 55 54 2D 53 49 54 20 16 03 15 4F 04 20 45 10 00 00 00 0A 00 00 00 00 00 00 00 4F 04 20 45 10 00 00 00 0A 00 00 00 00 00 00 00 D1 FA 0E 02 AC 82 07 E2 60 27 89 07 40 10 10 03 A3 28 64 92 01 35 73 14 01 4F 03 34 01 B3 A8 01 47 4B 07 00 A6 00 0E F9 00 00 10 01 00 05 13 54 91 64 02 AD 00 54 00 01 8A 17 3D 40 00 01 03 C5 00 D5 24 10 08 00 49 02 81 14 7B 42 80 00 00 9B AA 97 41 20 80 80 86 00 00 00 17 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 --------------- bit 4x4 ita cambio manuale kiles ho attivato uconnect 7 non vanno le porte usb+sd+aux
