Wrong state of SGW Giulia
DrVTH
Post by DrVTH » 11 Jan 2019, 18:06
in log file we can see that SGW is removed in node status, but still MES properly discovers existing SGW
CAN CONFIGURATION DATA:
4F 0C 40 65 10 40 19 02 0A 08 00 00 80 40 01 00 4F 0C 40 65 10 40 19 02 0A 08 00 00 80 40 00 00 04 00 00 00 00 40 00 00 02 08 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4F 0C 40 65 10 40 19 02 0A 08 00 00 80 40 01 00 4B 0C 00 65 10 40 19 02 0A 00 00 00 80 40 00 00 4F 0C 40 65 10 40 19 02 0A 08 00 00 80 40 00 00 4B 0C 00 65 10 40 19 02 0A 00 00 00 80 40 00 00 4B 0C 00 65 10 40 19 02 0A 00 00 00 80 40 00 00
30 34 36 32 30 30 30 32 35 35 31 4F 55 54 50 55 54 2D 53 49 54 20 18 09 05 4F 0C 40 65 10 40 19 02 0A 08 00 00 80 40 01 00 4B 0C 00 65 10 40 19 02 0A 00 00 00 80 40 00 00 43 5D 2F 01 A9 82 07 F3 54 31 A1 07 79 10 10 0A AB 1E 04 72 00 35 73 14 01 4F 03 34 19 83 AC 48 07 43 07 00 80 00 0C 4E 00 00 19 04 00 09 02 5B FA 9D 06 E5 05 31 20 01 71 15 3D 81 10 01 00 DA 00 B7 10 11 00 3D 49 03 03 12 F9 57 A0 00 00 01 00 00 F0 20 08 20 89 0A 00 00 00 00 00 0C 1C 00 00 00 00 31 00 00 00 03 00 02 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Automatic Transmission Node (TCM/NCA/NCR)
Gearbox Selector Node (ESM/GSM/NSC)
Driver Assistant System Node (DASM)
Radio Frequency Hub Node (RFHM)
Drive Train Control Node (DTCM)
Security Gateway Module (SGW)
Amplifier Node (AMP)
Comfort Seat and Wheel Node (CSWM)
Left Blind Spot Sensor Node (LBSS)
Right Blind Spot Sensor Node (RBSS)
Entertainment multimedia control module (EMCM)
Engine sound enhacement module (ESEM/ANC)
Parking Sensor Node (PAM/NSP)
Airbag Node (NAB/ORC)
Self-adaptive Headlamps Node (AFLS/NFA)
Haptical Lane Feedback Node (HALF)
(Multiecuscan 4.3)
30.12.2018 14:18:00
Alfa Romeo Giulia 2.0 Turbo 16V MultiAir
CAN Setup / PROXI Alignment Procedure (952)
Engine Control Node (ECM/NCM): EOL Ok
Automatic Transmission Node (TCM/NCA/NCR): EOL Ok
Gearbox Selector Node (ESM/GSM/NSC): Ok
Driver Assistant System Node (DASM): EOL Ok
Drive Train Control Node (DTCM): EOL Ok
Security Gateway Module (SGW): Removed
Amplifier Node (AMP): EOL Ok
Comfort Seat and Wheel Node (CSWM): EOL Ok
Left Blind Spot Sensor Node (LBSS): EOL Ok
Right Blind Spot Sensor Node (RBSS): EOL Ok
Entertainment multimedia control module (EMCM): EOL Ok
Engine sound enhacement module (ESEM/ANC): EOL Ok
Brake System Node (ABS/BSM/NFR): EOL Ok
Parking Sensor Node (PAM/NSP): EOL Ok
Airbag Node (NAB/ORC): EOL Ok
Self-adaptive Headlamps Node (AFLS/NFA): EOL Ok
Haptical Lane Feedback Node (HALF): EOL Ok
WARNING: SGW MODULE DETECTED! Active diagnostics will not be possible on this vehicle!
StokeR
Re: Wrong state of SGW Giulia
Post by StokeR » 16 Mar 2019, 22:30
How did you remove, deactivate the SGW?
