Fiat Stilo 1.9 JTD Bosch EDC15C7 (no Injector values readable)
Posted: 12 Mar 2018, 10:16
by DigiMike
firstly i would say, thats MES is really a great work, i can only say thank you for that!!
And now the issue:
I have the newest MES-Version and it works great with the most of readable Parameters.
But, it is not possbile to read the Injector Correction Values, the Class of the Injectors is readable,
the Actuatorstests works also fine.
To exlcude a missfunction of my ECU, I tried it on 4 Stilos with 1.9JTD (115cv,115cv,80cv,80cv) and Bosch EDC15C7, always
the same outcoming, that iam not possbile to read the Injector Correction Values.
I also tried an old Version of MES --> FES 3.6 same Problem
Configuration:
SW: MES 4.0 or FES 3.6
Interface: AGV4000 in KKL-Mode (had never a Problem with this Interface in KKL mode, use it on different Cars Subaru, VAG...., its works simply great)
ECU: Bosch EDC15C7
Hope you can help me!
Regards,
Mike
Re: Fiat Stilo 1.9 JTD Bosch EDC15C7 (no Injector values readable)
Posted: 12 Mar 2018, 11:05
Not saying that tis is your problem but I seem to recall from the distant past that this has occurred before and the solution was to true a TRUE KKL only interface.
While ELM and other interfaces can emulate/run in KKL equivalent mode for some ECUs a real KKL interface is required.
Posted: 12 Mar 2018, 11:18
by DigiMike
Hi, thanks for the reply.
I had this also in mind, your reply sounds like the same issue.
Maybe a cheap KKL-only Interface is a solution, I will get one and have a try with it.
Thanks!
Regards,
Mike
Posted: 14 Mar 2018, 08:05
by DigiMike
I tried it now with a KKL-Only and a China ELM237-Interface, same result, it is not possible to read the Injector Correction Values.
Have you maybe, any further Information for me?
Regards,
Mike
Posted: 29 Nov 2019, 09:18
by adamistr0
Sorry for reviving this thread, but have anybody managed to read the values of injector correction? I Have MES 4.2 and it shows only blank spaces. I have good ELM 327 cable, everything works (CAN, etc.) except this.
