Page 1 of 3
DRL settings for freemont failure on 3.6
Posted: 04 May 2017, 19:53
by sdmaino
Jumped from 3.4 to 3.6 and DRL settings for fremont are not working anymore.
Reverting back to 3.4 and all works OK.
Still did not test 3.5
Thank you for fixing
Re: DRL settings for freemont failure on 3.6
Posted: 13 Jun 2017, 13:17
by keebo
I'm new to MES, but today, using version 3.6, I have sucessfully set up DRLs (high beam / Canada) on my Freemont.
The point is that actual DRLs activation command (Not Present -> Present) seems to work correctly.
The problem is that when you open the setting again (after turning it ON) it still displays "Not Present" (although DRLs are actually activated).
So looks like the issue is not about inability to turn DRLs ON or OFF but rather in wrong displaying of DRLs status.
Hope this helps.
Anyway, it would be great if this is fixed as it's really misleading.
Posted: 15 Jun 2017, 14:10
by sdmaino
Thnk you keebo,
I saw this but it is not the only problem; whatever command I try to give, I get an error ("Error during execution" or similar popup, I can't remember) and the parameters are not changed.
It is not only visual in my case.
Thank you.
Posted: 20 Jun 2017, 23:20
by haffonso
I will do it on saturday i hope to get it done... i have a freemont.. what you guys suggest, high or low beams ?
Posted: 21 Jun 2017, 04:53
by keebo
That totally depends on your personal preference and, probably, legislation in your country.
I'm doing high beams so far :)
Posted: 21 Jun 2017, 09:16
by haffonso
:arrow: anyone knows the difference between drl canada and Europe?
Posted: 21 Jun 2017, 09:19
by haffonso
thanks keebo im from Brazil.. maybe no legislation lol.. but should be low beans i will do it with 8v..
Posted: 22 Jun 2017, 10:47
by sdmaino
haffonso wrote::arrow: anyone knows the difference between drl canada and Europe?
Nope. Already asked in another thread but the developer is silent...
Posted: 22 Jun 2017, 10:55
by sdmaino
haffonso wrote:I will do it on saturday i hope to get it done... i have a freemont.. what you guys suggest, high or low beams ?
I activated the DRL on my FOG lights.
I changed the FOG lamps with a couple of brigth white LED lamps, excellent result for my taste.
Posted: 23 Jun 2017, 00:09
by haffonso
Hello! Just enabled my DRL in low beams with 6.6V . Everything was ok and its running fine..
I'm still trying to identify Europe 1/2 and 3..
