Please tell me which version works. A service technician tried to activate the DRL with v3.6 on Freemont with Uconnect 4.3, FWD with manual transmission. He couldn't activate it because some kind of error popped up. He said he wasn't sure that this configuration is supported. Does anyone know or was able to activate the DRL on Freemont with Uconnect 4.3, FWD with manual transmission.sdmaino wrote:Jumped from 3.4 to 3.6 and DRL settings for fremont are not working anymore.
Reverting back to 3.4 and all works OK.
Still did not test 3.5
Thank you for fixing
DRL settings for freemont failure on 3.6
Re: DRL settings for freemont failure on 3.6
It worked for me and i could enable and the settings are : DRL enabled / Canada / High Beam / 6,8v
I don't know the difference between Europe 1/2/3 seems to be UK / W. Europe / E. Europe
Do you have 4.3 (small screen) or 8.4 (big screen) Uconnect? Manual/Auto and FWD/AWD?haffonso wrote:It worked for me and i could enable and the settings are : DRL enabled / Canada / High Beam / 6,8v
i have uconnect 8.4.. but there s nothing to do with uconnect.. this is the bcm module..
go to body module and adjustments.. the scanner should be multiplexed or with the connector mentioned in multiscanner site
no issues at all..
To configure DRL using the uconnect settings
Drl enabled
Drl Settings Europe 3 and not Canada... unless your country requires the headlights on all the time
voltage.. 7.0v but you can see the most convenient which is 24% of power consumption. you can see it in parameters in multiscanner..
Drl enabled
find the screen whre the drl should be configured
for Canada choose Canada.. if wish to control from uconnect use Europe 3.
- IMG-20170702-WA0003.jpeg (1.47 MiB) Viewed 4468 times
Thanks a lot for the information. Can you take a picture of the Uconnect menu and settings when Europe3 is enabled.
Just wonder how it is going to look on 4.3 screen.
If you choose Europe 3 where in the Uconnect menu the setting to control DRL shows up.haffonso wrote:find the screen whre the drl should be configured
I've just activated the DRL with latest v3.7.
