ISO Codes
devc
ISO Codes
Post by devc » 11 Mar 2010, 09:19
Hi Yani,
I notice in Fiat Examiner there is a option: "Ignore ISO Codes"
I think, if one can ignore the ISO codes, one can access more control units with the same communications procedures.
It may be worthwhile to look into that for your new version.
Thanks, you have been doing a fantastic job so far!
Regards,
Dev
Re: ISO Codes
Post by yani » 11 Mar 2010, 11:22
You CAN ignore ISO codes. Just press Y when the program shows the mesage "Invalid ISO Code! Press Y To Continue or Press N To Abort".
devc
Re: ISO Codes
Post by devc » 11 Mar 2010, 21:48
Oops, have not seen that yet. Sorry!
Regards, Dev
ARomeo
Re: ISO Codes
Post by ARomeo » 14 Mar 2010, 13:17
yani wrote:You CAN ignore ISO codes. Just press Y when the program shows the mesage "Invalid ISO Code! Press Y To Continue or Press N To Abort".
I pressed Y, but I coucn't see values of parameters
