elm327 r04
micapolo
elm327 r04
Post by micapolo » 26 Feb 2016, 11:22
Someone can tell me Where is R04 resistor to remove on this PCB ?
Thank's
https://imageshack.com/i/pmYyaNcIj
https://imageshack.com/i/plxMDwgfj
Re: elm327 r04
Post by Alfaeddy » 29 Feb 2016, 13:36
On your pictures do not see anything !!
Very unclear
Must you ever remove a resistor?
What car?
What control?
Which problem ?
you can not help without more information
micapolo
Re: elm327 r04
Post by micapolo » 29 Feb 2016, 16:06
I want read ecu engine Fiat ducato 2.3 jtd.
I have try other véhicules Fiat but i can t enter in ecu.
A few cars i can sometimes enter in simulate mode,but it won t connect.
Re: elm327 r04
Post by Alfaeddy » 01 Mar 2016, 10:54
The motor control of your Ducato is not read with CAN Bus
Therefore the bridge resistor (R04? or others) may not be your fault
Motorecu and ABS (adapter) you should also be able to read without modification
