Hi there
On the last couple of days I have been trying to connect to my Alfa Romeo Giulietta 1.6 JTD-m2 120 (2015) using an ELM327 bluetooth adapter (a cheap one) and MultiECUScan. I installed 2 different versions of MES, being 2.8R1 the last one I tried, but had the same trouble with both.
After pairing the bluetooth device and configuring the interface on MES with the outgoing COM port, the Test fails on ATSPC COMMAND with a time out. Am I missing something? Or is it a faulty adapter?
Thank you.
Command ATSPC... timed out
Re: Command ATSPC... timed out
I had the same problem. Windows 8.1 and 10 have a problem with bluetooth. You can try with windows 7 or Xp. I bought elm with usb and works well with windows 10 and multiecuscan
the issue is with the cheap ELM cables, not with the software
Hallo
Often enough, it is also the driver
or to the latency settings
Have you tried this driver ??
Choose OBDKey 1.40 in interface type
