Command ATSPC... timed out
grimreaper19
Post by grimreaper19 » 19 Jan 2016, 22:07
Hi there
On the last couple of days I have been trying to connect to my Alfa Romeo Giulietta 1.6 JTD-m2 120 (2015) using an ELM327 bluetooth adapter (a cheap one) and MultiECUScan. I installed 2 different versions of MES, being 2.8R1 the last one I tried, but had the same trouble with both.
After pairing the bluetooth device and configuring the interface on MES with the outgoing COM port, the Test fails on ATSPC COMMAND with a time out. Am I missing something? Or is it a faulty adapter?
Thank you.
gigi
Re: Command ATSPC... timed out
Post by gigi » 20 Jan 2016, 21:34
I had the same problem. Windows 8.1 and 10 have a problem with bluetooth. You can try with windows 7 or Xp. I bought elm with usb and works well with windows 10 and multiecuscan
outpass
Post by outpass » 08 Feb 2016, 13:10
the issue is with the cheap ELM cables, not with the software
Post by Alfaeddy » 14 Feb 2016, 09:58
Hallo
Often enough, it is also the driver
or to the latency settings
Have you tried this driver ??
Ripae
Post by Ripae » 12 Aug 2016, 22:54
Choose OBDKey 1.40 in interface type ;)
