MES and Windows 10
jeff23959
MES and Windows 10
Post by jeff23959 » 03 Nov 2015, 15:39
Hello All, MES v2.4-2.7 do not work with Windows 10 on my Acer Aspire PC
I had Windows 7, ELM327 USB and WiFi working fine on Windows 7. Upgraded to Windows 10 and could not get either USB or WiFi versions to work on same cars. Tried turning off Firewall / and everything else, or the usual culprits, no joy. Restored PC to Windows 7 and all working again now
Just for information, may be useful to some to save a load of wasted time
Re: MES and Windows 10
Post by alfa156sarajevo » 14 Nov 2015, 10:30
Thanks for feedback... Good to know... ;)
piotriix
Post by piotriix » 22 Nov 2015, 16:15
I also stopped working MES after the last update windows 10
piotriix
Post by piotriix » 23 Nov 2015, 07:43
Szczegółowe informacje na temat wywoływania debugowania w trybie JIT (just in time)
zamiast tego okna dialogowego znajdują się na końcu tego komunikatu.
************** Tekst wyjątku **************
System.AccessViolationException: Nastąpiła próba odczytu lub zapisu pamięci chronionej. Często wskazuje to, że inna pamięć jest uszkodzona.
w _getFiberPtrId()
w <CrtImplementationDetails>.LanguageSupport._Initialize(LanguageSupport* )
w <CrtImplementationDetails>.LanguageSupport.Initialize(LanguageSupport* )
************** Zestawy załadowane **************
mscorlib
Wersja zestawu: 2.0.0.0
Wersja Win32: 2.0.50727.8670 (QFE.050727-8600)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
Multiecuscan
Wersja zestawu: 2.8.0.1
Wersja Win32: 2.8.0.1
CodeBase: file:///C:/Program%20Files%20(x86)/Multiecuscan/Multiecuscan.exe
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Windows.Forms
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Windows.Forms.resources
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_pl_b77a5c561934e089/System.Windows.Forms.resources.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
mscorlib.resources
System.Management
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
System.Data
Wersja Win32: 2.0.50727.8677 (QFE.050727-8600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_64/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
************** Debugowanie w trybie JIT **************
Aby włączyć debugowanie w trybie JIT (just-in-time), plik .config tej
aplikacji lub komputera (machine.config) musi mieć
wartość jitDebugging ustawioną w sekcji system.windows.forms.
Aplikacja musi być również skompilowana z włączonym
debugowaniem.
Na przykład:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Gdy debugowanie JIT jest włączone, wszystkie nieobsługiwane wyjątki
są wysyłane do debugera JIT zarejestrowanego na komputerze
i nie są obsługiwane w tym oknie dialogowym.
piotriix
Post by piotriix » 23 Nov 2015, 07:54
Ok I solved topic.
Uninstalling Microsoft .NET Framework and reinstall helped .
In total, only the November update 10 so messed
