Alfa Selespeed hydraulic pressure
ratatouille
Post by ratatouille » 11 Feb 2010, 12:18
Hi Yani,
Many Thanks first for this great piece of Software !
Myself and other (Alfa) Selespeed drivers have a problem with some wrong values shown at diagnostic.
The pressure of the Selespeed hydraulic is wrong calculated.
AlfaDiag shows 55 bar (which is correct) were multiecuscan shows 63 bar.
The correct scaling formula for the Selespeed hydraulic pressure is: (X-100)/10.4
Is there a chance to get this corrected in the next Update?
What is missing for the Selespeed too is the status code number which is produced in case that for example the EOL calibration has failed.
I know that you don’t own a Selespeed car yourself, but maybe you can have a look (we can tell you afterthat if it works).
We miss the Bosch Motronic ME3.1 Engine Management too. Any chance for the next update?
Cu and Thanks again
JJ
Re: Alfa Selespeed hydraulic pressure
Post by yani » 11 Feb 2010, 15:29
Thanks for reporting the formula mistake. I enter the data by hand and mistakes happen sometimes. It is fixed now and will be ok in next release.
I know about the status from selespeed routines. I'm working on a new version where the status will be available.
Unfortunately, I will not have enough time to include ME3.1 in the new version.
ratatouille
Post by ratatouille » 12 Feb 2010, 08:43
Hi Yani,
Great news ! Thanks !
We will look forward for your next Update.
JJ
nb: you have a PM
