Alfa 159 JTDm 16v
brera32
Alfa 159 JTDm 16v
Post by brera32 » 10 Feb 2010, 20:22
Does anybody can help me?
I have an 159 1.9jtdm16v.
Today i tryed the Software first time...realy great.
Now my problem.
Everything is working,i can erase engine faults even the actuators are working.
But THERE IS NO ENGINE PARAMETERS SHOWN .
If i select any of the engine arameters the discribtion on the bottom of the screen is shown but on the right there is no parameters.
Do i anything wrong :?:
Brera32
Re: Alfa 159 JTDm 16v
Post by yani » 11 Feb 2010, 11:17
The parameter has to be selected in order to read the data.
You can do this by clicking on the checkbox (on left) or by pressing space bar. The parameter name will be colored in red and begin to read data.
tomsa
Post by tomsa » 12 Feb 2010, 07:37
Hi brera32,
i got the same car/engine but i can not do anything with the actuators.
can you post me your SW-version and ISO-code?
thanks.
tomsa
http://tomsa.bplaced.net
brera32
Post by brera32 » 12 Feb 2010, 10:33
hy Yani
I did all as you expained.
Parameters window open.. I would like to make a cross in the checkbox but no cross appears an no parameters on the right are shown.
The box is highlighted and the discribtion on the bottom apperars.
But i can erase Faults of the ECU...
Maybe you have an Idea.
Will try today an alfa 147 1.9JTDm8v lets look what happens..
Hy tomsa
Will have a look for the SW-Number and Iso Code Today..You will get it in the Evening
Is the parameters window working on your Car?
Brera32
tomsa
Post by tomsa » 12 Feb 2010, 10:54
parameters reading is working perfect except of odometer (=0).
Tomsa
brera32
Post by brera32 » 12 Feb 2010, 16:43
Hallo Yani
Now it works, i just was to stupid to follow your instructions :oops:
Thanks for helping...
Hallo Tomsa
My engine ECu ISO-Code is: FD 86 3D 04 19
SW NR: 1037377871
Version: 3442
THANKS Brera32
tomsa
Post by tomsa » 18 Feb 2010, 14:36
my Car is:
SW NR: 1037380494
Version: 3441
For me the parameter reading is working, but Air mass desired and air mass MAF are the same - could not be!
The actuators are not working at all.
@ Brera32
What happens when you use the EGR actuator? Can you see the change in the air mass?
tomsa
ARomeo
Post by ARomeo » 14 Mar 2010, 13:25
tomsa wrote:Hi,
Tomsa
The same situation odometer1 and odometer2 are 0.0
