elm 327 proplme
alikut99
elm 327 proplme
Post by alikut99 » 01 Jan 2013, 15:26
i have suzuki grand vitara 2010 eng 2.4L
and i bougth this elm 327 from amazon
http://www.amazon.com/BestDealUSA-ELM32 ... USB+OBD+II
but notwork ( no vehicle response)
Re: elm 327 proplme
Post by Alfaeddy » 01 Jan 2013, 17:34
Hello the Grand Vitara is not in the list!
Only the SX4 and including the
1.9 DDiS and 2.0 DDiS
But no 2.4 engine!
kellogs
Re: elm 327 proplme
Post by kellogs » 30 Jan 2017, 13:58
Eddy, will it work with a 2015 vitara 1.6 ddis ? In case it does, what can I read from the ABS module ?
thanks
Re: elm 327 proplme
Post by Alfaeddy » 01 Feb 2017, 10:34
Ok then reading should be possible.
To know what to read in the ABS.
Download Multiecuscan in the free version and
Make a simulation with the ABS of your model
kellogs
Re: elm 327 proplme
Post by kellogs » 02 Feb 2017, 22:25
Okay, dlded and ran simulation. I have a couple of questions:
1. why does elm327.ro sell the licence cheaper than you do on the main site ? 199 ron is less than 50 euros. Are they still legitimate ?
2. and what if the software fails to talk to the suzuki, do I get moneyback if I produce a video with it not doing the job ?
3. What I was after were individual travel distance by each wheel. I can track each wheel's speed I can see, but not each wheel travelled distance. Is there any way to determine that, maybe via logs, graphs - that could work if there were enough readings per second. How many readings per second can I expect of a cheap chinese bluetooth elm 327 dongle ?
thanks again!
Re: elm 327 proplme
Post by Alfaeddy » 05 Feb 2017, 18:28
I'm trying to give you answers, even though your questions should be the Mod or Yani.
To 1st currency differences ??
To 2. I am no Mod or Admin here, but I think times bought is bought, and why should the reading with your Suzuki not work?
In other vehicles it is also
To 3. Therefore, I have you with the simulation to see what data you can read and again said most Chinese ELM interface does not work with Multiecuscan
