AR 159 cooler fan test don't work
Posted: 13 Aug 2012, 09:05
by eric
Hi Yani,
here the topic again.
The test for the cooler fan with a MY08 AR 159 1.9 16V dont work.
It works with a MY06 and MY07
Re: AR 159 cooler fan test don't work
Posted: 13 Aug 2012, 10:23
by yani
Did you test it with the new version?
I made some improvements on the FAN control for this engine.
Posted: 14 Aug 2012, 10:47
by eric
I will try it today, thx for your reply.
PS: Can you reduce the blocking time between two answers?
Posted: 15 Aug 2012, 04:00
by eric
Don't work :(
ECU ISO Code: FD 86 3D 04 19
15.08.2012 05:56:51
CONNECTED TO:
Alfa Romeo 159 1.9 JTDm 16V
Bosch EDC16C39 CF4/EOBD Diesel Injection (1.9, 2.4)
ECU ISO code: FD 86 3D 04 19
FIAT drawing number: 51847392
Hardware number: 0281015160
Hardware version: 00
Software number: 1037398252
Software version: 3842
Homologation number: 93942
ECU programming date: 07/09/2008
READING PARAMETERS:
Fan speed:
READING PARAMETERS:
Fan speed: Not active
Fan 1st speed:
READING PARAMETERS:
Fan 1st speed: OFF
Fan 2nd speed:
READING PARAMETERS:
Fan 1st speed: OFF
Fan 2nd speed: OFF
READING PARAMETERS:
Fan 1st speed: OFF
Fan 2nd speed: OFF
READING PARAMETERS:
Fan 1st speed: OFF
Fan 2nd speed: OFF
READING PARAMETERS:
Fan 1st speed: OFF
Fan 2nd speed: OFF
READING PARAMETERS:
Fan 1st speed: OFF
Fan 2nd speed: OFF
EXECUTING ACTUATOR...
Fan 1st speed (coolant)
COMPLETED
Fan 2nd speed (coolant)
COMPLETED
The ECU for the was renewed, there is also a new one since around 08/08.
I don't tested it with the old ECU.
I have also just one fan, but the MY06 that i tested (where it works) also.
The 1.9 16V Qtronic has two fans
Posted: 12 Oct 2012, 06:24
by eric
Hi Yani,
any news?
Posted: 12 Oct 2012, 09:35
by yani
Sorry, no news on this issue...
